New tire blowout
Discussion in 'MINI' started by 08 Cooper S, Oct 20, 2015.
  1. 08 Cooper S
    08 Cooper S New Member
    Sep 22, 2015
    14
    Woodworker
    Northford, CT
    Has anyone had a Michelin sidewall blowout like this before? The tire is brand-new, how can such a thing happen? Possibly a factory defect??
  2. Savvy
    When was the tire made? That looks like dry rot.
  3. MCS02
    No but I know I would be on the phone with Michelin. Glad your ok. How fast were you going when it happened?
  4. old81
    No, but I agree that looks like dry rot. What is the date on the tires, tread depth does not equal a good tire.
    If it was less that 3 years old, call the manufacturer and see what they say!
  5. gjxj
    gjxj Member
    Jun 16, 2015
    32
    11
    Since the tire is brand new then yes it could very well be defect. As others have said what's the date code on the tire? Low pressure can also cause a failure.
  7. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    So..... what happened?
    What was the date code on the tire that blew?
    Did you talk to the place that installed the tires? What did they say?
    Do you have 3 other ticking rubber time bombs on your car?
  8. 08 Cooper S
    Sep 22, 2015
    14
    Woodworker
    Northford, CT
    So, to try to answer your questions, about my question.
    MFG: week 38 in 2013
    Speed: 40 mph
    No other problems
    The story on the tires:....
    My buddy purchased a 2014 coupe John Cooper with this tire/wheel combo on it. He changed the wheels/tires after 400 miles because they(his wife) did not like the black style wheel (I love it...) They sat around for a little while in his garage. I purchased them & put them on my 08. That was 2 weeks ago. The tires still have the little nubbies on them!!
    Do I call Michelin direct & what could I expect out of such a call??
    BP
  9. Savvy
    You can try... but buying them secondhand you may be up $#!+'s creek.
    This is true, but if the guy is your buddy he might be able to get the dealer (or Michelin) to replace. He just needs to not mention they were on your car at the time...
  11. Firebro17
    Maybe your buddy has a paddle.....
    Given that date stamp, if nothing else I think this ^ is a good reason to contact Michelin. They may be no help but I'd still try it...that is, if nothing else works.
  13. Firebro17
    I agree with the alarm over the age of the rubber. I'm thinking, even with the date stamp as it is, if that other guy's car sat much without moving, or if after that set was removed they were stored improperly, well... Who knows..?
    Tuff luck though on the Michelin's. I'd get together with your buddy to make Michelin answer some questions.
  14. Firebro17
    I did some checking and found Michelin has issued a safety recall on several of their tires, for sidewall blowouts on new tires. Check the Tire Safety Group website to see if your tires are included in the recall. I've attached a snapshot of the page I was reading. Good luck and please keep us up to date on the results.
  15. 08 Cooper S
    Sep 22, 2015
    14
    Woodworker
    Northford, CT
    I called Michelin, and to my surprise, I was speaking to a rep within 1 minute. I told him the issue and my concern for safety and the other 3 blowing out. He explained that if it is indeed a defect, it will need to be noted by a dealer & a direct call to Michelin describing the problem. If it is a safety issue, then Michelin will replace 1 or all tires at no charge. I was put on hold for about 2 minutes as He checked my area for a dealer (It was Town Fair Tire), called them and made them aware of the case.
    So today I made it down to TFT with the car and blown tire, they "inspected" and it drew some attention as they have not seen such an issue. The tire was discontinued & they are recommending that all 4 be replaced for the sake of safety. Unfortunately, they were closing and asked me to come back in the morning, because these type of things could take a bit of time.
    We will see! I am hopeful!
    Thank you all for your feedback. I would not have made it this far without you! BP
  16. 08 Cooper S
    Sep 22, 2015
    14
    Woodworker
    Northford, CT
    I used those exact words with Michelin, They were immediately more attentive!
    Thanks!
  17. BruceK
    Feb 24, 2015
    Texas
    Excellent progress. Good luck tomorrow.
  18. 08 Cooper S
    Sep 22, 2015
    14
    Woodworker
    Northford, CT
    Update...
    Apparently Michelin no longer makes a run-flat tire for the Cooper?? This is what they told Town Fair Tire, and because TFT refused to put a non-run-flat tire due to safety, Michelin is paying for a set of new Run-Flat All season Bridgestones for the car. Labor & Material!
    They will be installed today. Have a great day!
    BP
  19. Savvy
    Well, you made out like a bandit then. Good going!
    Although, if I were you, I'd sell the run flats off to someone and get non-runflats.
  20. Firebro17
    Yep, it's great to hear that you're being taken care of by the vendor. I second the idea of ditching the run flats. You'd really like the Michelin Pilot Super Sports if you'd prefer to stay with that brand.
