Brakes Wheels 2nd Gen Tires New Tires??
Discussion in '2nd Generation: 2007+ R55 through R61' started by mrminimmel, May 4, 2011.
  1. mrminimmel
    mrminimmel New Member
    Dec 5, 2010
    69
    Well, I'm getting to the point where the runflats are looking kind of nasty
    (autocross has worked its magic on them) and in a little while I'll be able to convince myself that a new set of tires that combine street use and autocross needs are in order. I know there are tons of opinions out there so start throwing them my way if you please. I live in AZ, I have 195/55/r16 on now. I have new Koenig wheels that are, I think, 7" wide, maybe 6.5". I read a review that the Bridgestone Portenza runflats were great but I think I'd rather stay away from runflats. I still have the stock rims but I'm not sure about the idea of having a dedicated autocross set of tires. Thanks.
  2. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    mrminimmel,
    My experience on these types of threads is you end up more confused that when you hit the 'send' button on your OP
    EVERYONE has a opinion on tires. Weeding through who has the same needs as me can be headache inducing
    My recommendation? Go to TireRack, Look up Summer Performance Tires ( all the flavors) and start looking at where your price point is and reading up in the rating tables.
    I've found it more informative than asking these types of questions on MA. The responses you'll get are well intentioned but you have no idea of what someone who replies driving style might be compared to yours
  3. BThayer23
    Tim's point is valid, Tirerack will have a lot of info that will factor into your decision, including cost and availability. If you want an autocross tire, I'd recommend anything in the extreme performance summer tire category. There isn't anything in the 195/55/16 size, so consider other similar sizes and research the forums to see what fits.
    Here's a few thoughts:
    Hankook R-S3: The latest "it" tire, less $$, probably noisy on the highway
    Dunlop Star Spec: Used to be the "it" tire, less $$, noisy
    Bridgestone RE-11: Fantastic tire, more $$, quiet on the highway
    Yokohama AD-08: Great tire, more $$, quiet
    Kumho XS: good stick, less $$
    You get a little more stick and a lot less highway noise for more money with the RE-11 and AD-08, but for a lot less money you get almost as much stick with the Star Spec and R-S3. I'm not a big Kumho fan at all, but you may like them.
    Testing the New Extremes of Extreme Performance Summer Tires
    Top Tires: Grassroots Motorsports Magazine Articles
    And if you want a tire that lasts more than 15,000 miles, you're talking about something that sacrifices grip for mileage, and we're having the wrong conversation. Then you're looking at a Conti ExtremeContact DW, or something similar that I know nothing about.
  4. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    Since you want to use tires for street and Auto-X, you first need to decide what range of tire wear is acceptable.
    I use my tires for street and about 3 Auto-Xs a year. So I tend to look for tires more for the street than Auto-X. I usually look at tires around the 280-300 rating and I get around 16000 miles out of a set of tires.
    I have used Toyo T1R and now have Hankook Ventus V12. The V12s are inexpensive, pretty sticky, low noise, and wear OK. I think one size in 16".
    If you accept less tire wear you can get stickier tires better for Auto-X. Look at some of the tires in the 200 rating range.
    You will be limited at the 195/55-16 size. I suggest at least going to 205/50-16 for a larger selection of non-runflats.
  5. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Tim makes a good point. You can certainly get info overload asking the imfamous tire question.
    Round 3: You are getting good tire advice here; the two guys above know thier stuff when it comes to tires. :Thumbsup:
    However (c'mon you saw it coming ;) ), if you want a decent (good wet and dry traction) street tire that will last some miles 20-30k miles and keep you happy enough at the autox I'd say go Hankook Ventus V12 Evo like quikmini recommended. Good tire with a nice 16in wheel option.
    It doesn't sound like you are too hard-core about autox. I'd say skip having the spare rims. One less thing to worry about the day of the event. That being the case I recommend one of two tires:
    Hankook R-S3s (they live well with the heat and keep thier stick)
    or
    Dunlop Starspecs (Not quite as sticky but they will live more road miles)
    The caviat is that I don't know if they tire sizes in 16in.
    I have experience with all three autox'ing in Las Vegas Region SCCA so I understand the 115 deg f day of autox.
  6. mrminimmel
    Dec 5, 2010
    69
    So what do you consider hardcore on the autocross? I plan on 1 a month maybe even 2 occasionally. I've done 6 events since Dec and my goal of wearing out the runflats is working. I talked to Discount and they can flip the tires and rotate to help get more life out of them. I'll look at tire rack for info. Thanks, Pete
  7. am0eba
    am0eba New Member
    Dec 16, 2009
    158
    SoCal - LA County
    I can respond factually on three specifics:
    1. life without runflats - it can be a little worrisome, especially when away from "civilization", but the runflats don't really provide that much more security or peace of mind, because they don't run that far when flat, and if they get a puncture anywhere but in the flat part of the tread (i.e., the sidewall or shoulder) they can't be patched with a plug, so you need to get them replaced, which can be substantially more difficult when in the boonies, than for a non-runflat tire. Also the expense of replacing runflats is ridiculous... Most folks will make the point that you can get a SET of non-runflats for the price of replacing a single runflat. Some things that can mitigate the risk of running non-runflats: carry a DC powered compressor and "goop", which can get you to a service station, or at least someplace with cell-coverage; a charged cell phone and the number for MINI Road service and / or AAA to get a tow to the nearest service station; some tire plugs and a tool, in case it's an easy one... you can DIY, and save some grief; if you're really concerned, and you can "spare" the room, purchase and carry a compact - or full-size- inflated spare tire and rim.
    2. 205/50R-16's will fit on a stock suspensioned R53 (first-gen new MINI). I can't speak for the R56's or other variants, but I've run several brands and models of tires in this size on my 2005 MCS ragtop since June 2005 with no rubbing or other issues. I'm certain wider tires would fit without difficulty as well. (Running Konig "Holes" in 16x7" with a 42mm offset.)
    3. Dunlop Direzza Star Specs come in 205/50R-16. I'm running them now.
    _Dave_
  8. ScottinBend
    And remember to take a close look at the wear ratings. They are not 100% accurate, but they will give you a very good idea on the wear and mileage you can get out of them. I was able to get about 25K miles from my GY F1's and they have a wear rating of 300. So I decided my new tires were going to be at least a wear rating of 250 as I need to maximize my mileage vs grip at this time.
  9. Redbeard
    1,636
    398
    Not entirely true... Certain runflats can be patched. My tire guy at Discount Tire showed me an internal document stating which RFTs can be patched and which cannot. I don't remember the whole list but: Dunlop, Continental, and Michelin runflat could be patched and Pirellit and Kuhmo could not. There were other brands but that's what I remember from the list.
    Otherwise Dave makes VERY good points as far as the cost/benefit of non-runflat tires.
    I run on standard tires. I keep two cans of Fix-a-Flat in the car with me at all times for just that reason. :Thumbsup:
    "Hardcore" autox is planning on running Pro-Solos and Nationals with the intent to win. If you are just having a good time with your region that isn't hardcore.
  10. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    (For what it's worth) I just did a AutoX with the AD-08 and they were excellent, stuck like glue, quiet on the highway. When I got the Yoko's it was a toss up with the Dunlop's. I saw many people running the other tires above at the AutoX however do not have personal experience
  11. am0eba
    am0eba New Member
    Dec 16, 2009
    158
    SoCal - LA County
    @Redbeard: My point was that plugs won't work on the shoulder or sidewall of ANY tire, which means replacement instead of repair, and runflats are much more expensive to replace... Didn't word it very well I guess...
    _Dave_
  12. Redbeard
    1,636
    398
    Ah! There ya go. Only issue with the internet. Easy to misunderstand. :Thumbsup:
    Well then I lean on the second statement, Dave makes very good points. :D
  13. mrminimmel
    Dec 5, 2010
    69
    #13 mrminimmel, Jun 30, 2011
    Thanks for the info and ideas to consider about tires and guess what? About a month ago we fell into a deal with a used Cooper S and I decided to try some new lighter wheels with more offset and some yokos AD08s on them. A couple guys at the local autox love them and I'll let you all know how they feel. How long and what does it really take to wear the mold release compound off? I don't have to drive slow do I? And by the way the wife loves to drive the "old " Cooper.
  14. quikmni
    quikmni Moderator
    Jun 6, 2009
    774
    174
    Aerospace Engineer
    Orcutt, CA
    I usually only notice the mold release for a day or so. I would guess it wears off in 50 miles or so. You do not need to drive slow but you might notice the tires feel a little greasy and squirm a little.
  15. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    They were sticky from the get go and only get better
  16. mrminimmel
    Dec 5, 2010
    69
    Yikes,
    how time flies! I blew through the Yoko AD08s with lots of street wear, a driver's school, an EVO Phase 1, and a few local autocross events. I loved the tires but think the lower price of the new Hankook Ventus RS 3's will be appreciated. They are also on the spare lighter 17 inch wheels that will be dedicated to autcross. I just ran them to get off the mold release gunk and I love the feel. Can't wait till the next event.
  17. Zapski
    Some good info in this thread, I'm glad it got bumped up. :)
