2nd Gen R56 Cooper S new to M/A need help with code 2772, 2773
Discussion in '2nd Generation: 2007+ R55 through R61' started by 08Shelby, Sep 30, 2017.
  1. 08Shelby
    08Shelby New Member
    Sep 30, 2017
    I need some help working on my son's '07 R56 MCS, that we just bought used with 146,000 miles(he is 16). I had the noisy timing chain and hard valve seals and ended up with 2 bent valves before I got the timing chain replaced. I ended up pulling the head and cleaning up all of the carbon build up, replaced the timing chain, tensioner, 2 exhaust valves, and valve seals. The car runs awesome and idled a little rough initially until I replaced all 4 plugs. Since then it runs smooth, and strong, but I get codes 2772, 2773, and 27C4 using a Snap On Verus scan tool. I tried switching coils to see if the code moved to a different cylinder, with no luck.
    This is our first Mini experience after numerous Mustangs, and it is the coolest little car!! Any help would be greatly appreciated!!!
    Jeff
  2. Redbeard
    1,636
    398
    Glorified spreadsheet jockey.
    Those codes are all related to fuel pressire and evaporation. I would look to see if the high pressure fuel pump was replaced under the national recall.
    Otherwise have a look at the evaporation cannister. I'm not sure where it sits but it's part of the fuel vapor recirculation system.
    Those will most likely be the cause of the issue.
  3. vetsvette
    Check your gas cap too. That's part of the same system.
  4. MCS02
    6,328
    I have nothing to add but welcome to MA!
  5. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
