New to me 2013 Roadster J
Discussion in 'Starting Line - New Member Introductions' started by eddieloft, Dec 12, 2016.
  1. eddieloft
    eddieloft New Member
    Dec 10, 2016
    Hi, Everybody!
    I just got a 2013 Roadster J. It sure looks expensive to repair and maintain through the Dealerships so I will try to do most of the maintenance myself as I have done on my other cars. Does anyone know where I can buy a repair manual for the 2 GN Roadster J? I have not had any luck so far. Thanks for your help.
    Eddieloft
  2. DneprDave
  3. eddieloft
    Dec 10, 2016
    Roadster Manual
    Hi, Dave!
    Thanks for your reply. The Bentley Manual doesn't seem to list the Roadster in the contents. How do the dealerships repair and service the Roadsters if there is no manual for them? Thanks again,
    Eddieloft
  4. MCS02
    6,315
    Welcome to MA!
    The Bentley Manual should have everything you need minus the top & assorted parts.
    What is the J part of your roadster?
    Welcome to M/A
  6. 00Mini
    2,259
    Welcome to Motoring Alliance the onlyest MINI forum you'll ever need and congratulations on your new ride !!
  7. DneprDave
    The roadster is mechanically the same as the other small MINIs. So, other than some body specific things, the Bentley manual is good for the roadster.
    The dealership has their repair manual digitized and they print what they need for specific jobs.
  8. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    First and for most, congrats Eddie!
    Secondly, in August 2017 our car will go out of warranty. Last August it went out of free service so getting a manual might be the right thing to do...
    Quick question for those who have the Bentley manual: Does it lists all proper bolt torque numbers? I always like to use the proper numbers.
    Side question: Other than the usual wear items like brakes, oil changes (which I did one already quite smoothly), oil and air filter, what other items does MINI techs do on their scheduled services in the long run for minis?
  9. Dave.0
    Does it lists all proper bolt torque numbers? I always like to use the proper numbers? YES, the manual list the specs.
    The dealer should have a list of things they "Change" and things they "Check" for scheduled service levels.
    *Note the more they "Change / Replace" the larger your bill will be.
    Bear in mind that dealers will always try to make more money by adding on things. Fuel system flush, power steering flush a new MINI air freshener? I ask them to show me where in the factory list of things to service these are shown. Cash cows for the dealer. I'm not anti dealer, but I am anti screw with my wallet.
  11. TG.
    TG. Active Member
    Mar 2, 2014
    159
    70
    Yes indeed, hence why I'm trying to get informed on what's good to put in my own DIY service schedule for this little guys :biggrin5:
    Planning to keep it for the long run so good maintenance is key... as long as I know what that is :lol:
  12. Dave.0
    The #1 think to keep any MINI is good working condition is Change your oil often.
    Some like me still stick with 3-4 k because OEM paper filters don't filter well after 8k to 15k.
    Oil may last longer than 3-4k but do you really want very dirty oil and filter in you car for much more than that?
    Fresh oil and cheap costing good OEM filters are cheaper than motor rebuilds. :idea::ihih::Thumbsup:
