New-to-me mini owner in desperate need of help - Code: P2719/P2720
Discussion in '2nd Generation: 2007+ R55 through R61' started by plackslayer, Aug 11, 2018.
  1. plackslayer
    plackslayer New Member
    Aug 11, 2018
    P2719 - Pressure Control Solenoid 'D' Control Circuit Range / Performance
    P2720 - Pressure Control Solenoid 'D' Control Circuit Low
    2013 Mini Coupe base.
    I have the car on jack stands right now and need help fixing this problem but there is nearly NO helpful information on the internet about doing it myself.
    Desperately seeking help!
    Thanks in advance for your time,
    --PS
    Sorry I am not mech help on this one But Ill give you a bump. Someone will be able to help.
  3. Minidave
    4,594
    Those are automatic transmission codes, have you checked your trans fluid level? Do you know how to do that? On these cars you start the engine and run it till the fluid is about 90*, then remove the transmission drain plug, fluid should gently run out - if not you're low. Add fluid till it does run out then check it again. It uses the same fluid as a Toyota, Type T- IV
    • Like Like x 2
    • Informative Informative x 1
