Engine Drivetrain 2nd Gen S NM-Eng Upgrades installed
Discussion in 'Tuning and Performance' started by Rockridge, May 13, 2012.
  1. Rockridge
    Rockridge Member
    Oct 12, 2009
    32
    Director of Software Development
    This weekend the folks at Greasy's garage installed a bunch of new parts on my mini to help it breath better.
    - NM-Engineering Hi-Flow Intake
    - NM-Engineering Discharge Pipe
    - NM-Engineering Air Charge Pipe
    - Forge Alloy Intercooler
    - Mini-Fini Intake scoop grill
    In addition, I had the following suspension items installed
    - NM-Engineering Billet Tie-bar
    - H Sport 25mm Rear anti sway bar
    First thing I noticed when driving it home, was how quiet it was, could not believe the change from JCW intake and eliminating the noise maker made on the level of sound in the cabin. It's so much quieter.
    Second thing I noticed, was how light the car felt. At low end it seemed to have more pickup, and was great at surging through the gears.
    Here is a picture of the engine bay.
  2. kent kanipe
    kent kanipe New Member
    Oct 21, 2010
    79
    17
    Corvallis, Oregon
    Nice job! I have those same mods save for the scoop girl and my bar is 19mm and have never regretted the changes. Smiles for miles and miles. Congrats.
    Kent
  3. BRG_Paul
    BRG_Paul Active Member
    Nov 20, 2011
    758
    184
    Turbomachinery Engineer
    York, PA
    You may want to check your MINI FINI scoop grill...they had a batch escape that were the wrong stainless alloy. The bad batch can rust a bit along the laser cut edges. If yours is magnetic then it's part of the bad batch.
  4. Metalman
    Yep, if it's magnetic, it's part of the 400 series family (probably 430 stainless steel). The 304 has more nickel and chrome to the point where it's non-magnetic and is better at resisting corrosion.... I won't stock 400 series in my shop for the simple reason it's too easy to grab the wrong alloy by mistake....
  5. Rockridge
    Rockridge Member
    Oct 12, 2009
    32
    Bummer. I pick it up from Waymotorworks, and painted it flat black on both sides. If it is part of the bad batch, I hope that will help. I'll check with a magnet tomorrow.
  6. Jason Montague
    #6 Jason Montague, May 13, 2012
    :cornut: I have the same mods but from an unnamed company who doesn't sponsor MA. I got them years ago before there was an MA. I had to replace the silicone turbo intake hose with a non collapsible metallic pipe and now all is well. :Thumbsup:
  7. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
  8. CHKMINI
    Looks great! I wish that NM made the Intake Kit with a red tube and red filter. The tube is easy to change to red but the blue filter would look bad under my bonnet.
  9. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    I can tell you it makes the turbo sound amazing. As far as horsepower gains I had my doubts...
  10. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Mark I would guess you could find a K&N Filter that would fit.
  11. Rockridge
    Rockridge Member
    Oct 12, 2009
    32
    When I installed the intake, I also installed a new FMIC, plus boost tubes, and removed the noise maker. Then, I installed the Stage1+FMIC map on my AccessPort. The car screams, and sounds amazing. Not sure if any one component was the key, but all together, I am VERY happy with the performance post install.
