No need for oil changes Ford Focus
Discussion in 'Other Vehicles' started by buttonbag, Jun 12, 2015.
  1. buttonbag
    buttonbag Active Member
    Apr 5, 2013
    178
    133
    So if you go to Ford's website and look up the Focus, Ford is claiming that the electric version of the Focus doesn't need oil changes. I'm a little skeptical about that claim, but I wanted to see what everyone here think. Is this true? Is it not? Is there a fine print on this claim?
    This is true, the electric version has no gas engine. It is a pure battery powered car.
    No gas either...
    But there is a 76 mile range according to the EPA, not exactly good for traveling.
  3. Metalman
    Ford Focus.... No oil changes.... Ever....??
    So there is no differential / transfer case?
    The electric motors are direct drive to the front wheels?
    It has a 1-speed automatic transmission.
    When one thinks "oil change" it is usually engine oil. Being this is has a Permanent Magnet Electric Traction Motor there is no need for an Engine Oil change.
  5. Metalman
    Sooo at 150,000 miles when the one speed burns up the auto clutches.....
    The mechanic might say sumptin like...... "Oh yeah, you shuda changed the earl":D
    "A re-built plus installation will run you about $8,000.00 +tax":D:D
    Unless of course they use "Lifetime" Earl", then thats a totally different song...
  6. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    I would also suspect electric motors have shaft bearings so there is a distinct possibility that bearing needs to be lubricated from time to time. But no oil change.
    Craven Speed created an Electric MINI, maybe Kellen or Tristan will chime in with maintenance info.
  8. rkw
    rkw Well-Known Member
    443
    If you take a car to a shop and ask for an "oil change", they won't touch the differential. It is a marketing web page and they are using a common meaning of the term.
    Craven Speed dipstick to check the depth of the electrons? Never changed the oil in our 2 stroke SAAB, but man did it burn it, a quart every tank full.
  10. ZippyNH
    If you can find a crankcase..... You can drain the oil...
    But no crankcase....no oilchange...
    You ever change the oil on your vacuum cleaner?!
    OK...maybe saying golf cart is more appropriate.....
    And the 76 mile range is under ideal conditions....
    Folks in the northeast found the electric LEAF could go less than HALF its rated range on cold days...batteries don't do well in the cold, then add that little electric HEATER running on a battery....
    VW tried a heat pump on a few models of thir electric car, but the extra $$$ vs the range was a killer....
    I see the day when electric cars have GASOLINE powered heaters like the old VW bugs....
  11. Metalman
    #11 Metalman, Jun 14, 2015
    Earl is earl.... Either it got's it, or it don't...
    If it got's it.... At some point it needs changing...
    If it don't got's it.... Then it don't need changin....:D
    These guys are Earlmen..... Actually, early Earlmen....
  12. ZippyNH
    Notice they said "no oil change" not "no scheduled maintenance"....
    It still gonna need something....just not gas in the tank, oil in the crankcase...
    Kinda like what happened when railroads went from steam to diesel....
    Or folks " parked" their horses at the local dogfood plant and bought model "a" cars from that Henry fellow...they no longer had to muck a stall....
  13. Dave.0
    All Electric Ford with one speed? That when I lost interest and don't care.
  14. _iD
    _iD New Member
    Apr 5, 2014
    62
    23
    Isn't the Tesla just "one speed" also? With all the torque available at like 0 rpm, there's no real need for gears.
  15. Dave.0
    Not a tesla fan either.
  16. _iD
    _iD New Member
    Apr 5, 2014
    62
    23
    You should drive one. The acceleration is unlike anything you've likely ever experienced.
  17. Metalman
    I'm sure if David.0 drove a Tesla.... He would trade in his MINI for one...
  18. walshe_ian
    walshe_ian Member
    Dec 18, 2010
    42
    Mini say the gearbox oil is lifetime oil lol and the fuel filter is lifetime aswell changed both at 45kk and they clearly needed changing
  19. Metalman
    "Lifetime" definition: the duration of a thing's existence or usefulness.....
    Sooooo..... With all the snickering about this "Lifetime" thing going on with BMW/MINI.... Perhaps their marketing people were very astute....
    Were we MINI owners thinking the oil or filter would last forever? Maybe BMW/MINI was really saying the lifetime of the item was only as long as it's usefulness.... Once you exceeded it's usefulness, you've exceeded it's "lifetime"...:idea:
  20. BlimeyCabrio
    What they really mean is the engineered lifetime of the assembly using the fluid. They fully intend for automatic transmissions to be disposable after 100k miles. It's our stupid fault that we expect them to last longer, in their logic.
