1st Gen R53 Cooper S Nw Oil Leak
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by RicSeale, Sep 5, 2016.
  1. RicSeale
    RicSeale New Member
    Sep 5, 2016
    greetings all
    my 2008 MCS has a new oil leak.
    the source appears to be a black plastic box
    directly above the rear-lower engine mount.
    i can find no reference of similar leak anywhere.
    it's not the chain tentioner, i have verified that.
    can anyone have any knowledge of similar leaks?
    pix attached.
    Thx
  2. rusty.daily
    rusty.daily New Member
    Aug 8, 2015
    9
    Can't see exactly but it looks like the oil pump solenoid harness is leaking,
  3. r34king
    r34king Member
    Aug 18, 2011
    71
    34
    Auto Tech NTB Capital BLVD
    That is the vacuum accumulator. If it is leaking oil you have a bad vacuum pump. The 08 didn't have oil volume control solenoids
    Also check front main seal
    Sent from my Nexus 6 using Tapatalk
  4. Dave.0
    That's not a leak, that's just MINI anti-rust protection process at work. :lol: Good luck
