OBDII scanner...anyone have one of these??
Discussion in 'MINI' started by Vernon29RW, Jul 7, 2009.
  1. Vernon29RW
    Vernon29RW New Member
    May 22, 2009
    115
    Pat-Med, NY
    Hey,
    I was sifting around all the random stuff on Amazon.com and came across this OBDII scanner/code reader from Autel for quite a nice price and wanted to know if anyone has seen one of these in use or has one. It says it not only can read DTC's but also freeze frame data and monitor/readiness codes. What do you guys think?
    [ame=http://www.amazon.com/Autel-MaxiScan-MS409-OBD-II-Scanner/dp/B001LHW9YG/ref=pd_sbs_auto_3]Amazon.com: Autel MaxiScan MS409 OBD-II/EOBD Scanner: Automotive[/ame]
    Thanks,
    Steve
  2. BlimeyCabrio
    I have the Harbor Freight branded version of that tool:
    - Harbor Freight Tools - Quality Tools at the Lowest Prices
    Actually mine is a generation older, but the same animal.
    It's *OK* - it will read codes, it will show FF data, it will clear codes, it will clear the auto transmission codes also.
    It will NOT see any of the BMW specific systems (e.g. ABS, airbags, IKE, body control module, CAN bus, etc.) and can't read any sensor data directly, etc. Just standard OBD stuff. And it takes a LONNNNG time to connect on a MINI (a minute or more usually).
    So it does a little more as a reader than my ScanGauge, but nowhere near as functionally complete as AutoEnginuity with the BMW extensions. But it's way less money than AE.
  3. Joemagraine
    Joemagraine New Member
    Jul 7, 2009
    Carplugs
    Check out this OBDii CAN Scanner
    I've been using it for a couple of years and it's great. Pc based, so you need a desktop, netbook or laptop computer.
  4. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    thanks for the responses guys. Paul where did you buy your AutoEnginuity software?? There's a guy selling it on Ebay for $200 without the BMW extensions. That doesn't seem like a bad price considering how much more it can do over those generic scan tool/code readers.
    Steve
  5. Vernon29RW
    May 22, 2009
    115
    Pat-Med, NY
    The other thing is, if you know, how does it compare to the CarSoft software?? Seems like either one can do SOOO much more than those scan tools can, especially for BMW vehicles
  6. BlimeyCabrio
    Steve - buy AutoEnginuity from bimmerzone.com - best price I've found new
    Some of the stuff on ebay uses their older hardware, which won't work as well with the newer software (including especially the BMW extensions if you decide to add later).
    CarSoft looks good from what I read - appears to do much of the same stuff at AE plus coding (which AE does not do)... but I don't know anyone who has it and don't know how the data logging, etc. compares.
  7. Metalman
    7,700
