OBDII
Discussion in 'MINI' started by SamtheSham, Jun 25, 2015.
  1. SamtheSham
    SamtheSham New Member
    Feb 18, 2015
    10
    Punta Gorda, Florida
    Trying to decide which OBDII I need to get to check my 2012 Mini Convertible. I have found that some units will not work on the R57 cars. Amazon has units priced from $18.00 to $48.00. Anyone bought one lately??
  2. Spa2k
    Spa2k Well-Known Member
    May 9, 2013
    1,955
    975
    Iowa
    I bought an ELM327 for $12 on Amazon to use with Dash Command in my R56. (The purple-and-gold labels on the OBDII units have different brand names, but they all seem to be the same inside.) The only other things I remember that you need to watch out for are Apple vs. Android - and WiFi vs. Bluetooth, depending on what devices you're running. Oh, and these suckers run really hot and suck a lot of juice if you leave them plugged in when your engine's not running; they can drain a battery overnight.
  3. nxtMINI
    nxtMINI Active Member
    Apr 26, 2010
    405
    40
    Michigan
    ^^ agreed with the above comment. I bought this one and works great with my iPhone on R56:
    ELM 327 Wi-Fi OBDII
  4. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    I got one of these last year and had to add an adapter cable to get it tucked away so that I would not knock it loose with my left leg. Extender cables for OBD2 are $5 on ebay
    I run Torque for Android on it with 4 displays and the data rate is fine to keep all those going.
  5. gjxj
    gjxj Member
    Jun 16, 2015
    32
    11
    really, nobody makes one that auto shuts off?
  6. 05r50
    05r50 Well-Known Member
    Dec 4, 2010
    1,269
    696
    Interesting.
    I have both an elm BT device and torque and also a scangauge.
    I never noticed the elm drawing power or being hot, but I never touched it to find out.
    I use the scangauge all the time and it doesn't show that it is drawing power when the car is off.
    Never had a battery get killed by either.
  7. Spa2k
    May 9, 2013
    1,955
    975
    Iowa
    Maybe it's a second-generation thing.
  8. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    I don't leave mine plugged in - but I mostly use it for diag purposes only, not daily logging or monitoring.
  9. 09PepperWhite
    09PepperWhite Active Member
    May 3, 2015
    136
    100
    Donation funds allocator non profit organizations
    United States of America & Texas is a Great State
  10. _iD
    _iD New Member
    Apr 5, 2014
    62
    23
