2nd Gen R56 Cooper S Odd door window question
Discussion in '2nd Generation: 2007+ R55 through R61' started by Mbroncosfan422, Jan 18, 2013.
  1. Mbroncosfan422
    Mbroncosfan422 New Member
    Dec 26, 2012
    13
    Mechanic
    Patchogue ny
    When u open the door the window goes down a lil so my question is what happens when the window is frozen ? Does the door still open if window can't go down ? I had a lil frost on my windows and was a lil worried to open the door cause I didn't want to break something if the window was frozen .
  2. ScottinBend
    It will try and dip the window when frozen. If the window actually has a lot of ice, not frost, best to scrape off the glass before opening the door.
  3. Jason Montague
    :cornut: COLD, never hot, water helps.:Thumbsup:
  4. Metalman
    I spray the window weatherstrip with aerosol silicone..... when dry, it prevents this bond from occurring....
  5. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
    It's going to take a LOT more than a little frost lol
  6. Angib
    You guys have it easy in some ways - it freezes and stays frozen. Over here winter temperatures are often below freezing at night and above in the day. So one day this week we had snowfall in the morning, thaw in the afternoon and heavy freeze at night, so I found that not only wouldn't the window dip, the whole glass was frozen to the weatherseal on my Roadster's roof. I had to pluck up the courage to just yank (/hoik/wrench) the door open.
    And then I got to 50mph and found that the boot spoiler was also frozen down, so the car went into a bonging frenzy with dire warning on the Visual Boost screen saying 'Reduce Speed' and 'visit dealer'. Dropping below 32mph did not stop the bonging, and neither did stopping to switch off the ignition. Luckily a bit of sunshine during my first job enabled me to clear away the ice, though the obsessive detailers would have had a heart attack to see me using an ice scraper inside the recess under the spoiler once I got it to go up.....
    Wow spoiler nanny sounds like she doesn't like you. Maybe it's just the cold weather that put her in a bad mood. :wink:
    Silicone spry on the weather strips really does help. :Thumbsup:
  8. Jason Montague
    :cornut: It sounds like that you've never been to Texas. The day/night drastic change is often the Texas norm. It is also said that," if you don't like Texas weather, stick around, it'll change.":Thumbsup:
  9. ScottinBend
    Also normal around here.......
    And the 303 Protectant works great at keeping the rubber seals from freezing to the metal parts w/o aging the rubber like silicone does.
  10. Metalman
    Scott...
    Silicones are inert.... They have no effect on aging of rubber....
    However rubber is not inert and will age....
    http://en.wikipedia.org/wiki/Silicone
  11. ScottinBend
    I should have been a bit more specific....
    DON"T USE THE ARMOR-ALL 'type" products....:biggrin5:
