2nd Gen R56 Cooper S Odd tapping noise
Discussion in '2nd Generation: 2007+ R55 through R61' started by Apok, Mar 18, 2014.
  1. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    So weekend before last I changed the oil and filter in my 10 MCS. Everything seemed to go quite well. But I have noticed that suddenly my idle gets a little rough here and there, but more disturbing is the tapping sound. Seems to be coming from the topish area of the motor. I heard the tapping really bad in the parking garage at the gym. Not sure if it's the turbo or maybe some valve tap? Any thoughts?
  2. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Just checked oil level, it's a tad over the full mark. So it's def not caused by an oil leak.
  3. MCS02
    Is it constant tapping? if so you can get a screwdriver and put your ear to the handle and put the point on different parts of the motor to find where its coming from. used a long screwdriver and be careful.
  4. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Yes, it is consistent. And I have just the screwdriver for the job.
  5. Dave.0
    Did you use an OEM filter? What oil?
  6. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Yup, oem filter from our favorite eminiparts and mobil 1 high mileage 5w-30, it was all they had in the mobile 1 in 5w-30.
  7. Dave.0
    Well that sounds good, I have no other ideas maybe some of the R56 can help you out.
  8. Metalman
    Has your chain tensioner ever been replaced? You have a 2010, and it may or may not have the improved tensioner.... The dealer can tell you with the VIN....
    MINI claimed to have fixed this problem several times over the spread of the early model years.... Not sure when they start using the improved one in production....
    If it's not getting pumped up with oil pressure, you could have extra slack in the chain.... Could be the ticking...... Just thinkin out loud....
  9. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Awww man, I hope its not that. But what would cause that with just changing the oil?
  10. Metalman
    If you do the screwdriver stethoscope on the passenger side of the engine and identify where the noise is coming from. That's where the timing chain is located.... The tensioner is pressurized by oil pressure.... The fuel injectors are also noisy.... You need to locate where the ticking is originating....
    The tensioner.... if the old style.... May be replaced at N/C by the dealer.... If not, it's an easy DIY and the part cost is around $40.00 if I remember correctly...
    But locate the noise first....
  11. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    So if I am just suddenly hearing the injectors clicking, that would just be along the top/back of the engine about where the injectors come in. Ill try to check it tonight, but after work I gotta go out to a funeral. So I may not get the opportunity to report back this evening.
  12. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    That's what is making the noise. Front right hand side of the engine.
  13. Metalman
    That is the vacuum booster pump.... Supplies vacuum to your brake booster on your brake master cylinder....
    That is the vacuum unit. It is driven by the exhaust cam & if it seizes you will lose your engine. I would not drive your car until you get it to the shop & get it fixed. I am not kidding.
    Have your car towed to the dealer or to Best Motor Werks.
  15. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Oh great, what's that cost?
    Engine is about $7,000. Don't know how much the vaccuum pump costs. My MINI is an R53 & doesn't have one.
    Call John over at Best & ask him. He should be able to give you a ballpark estimate.
  17. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    I was trying to find that part on eminiparts, but I'm not having any luck.
  18. Metalman
    Here's the vac pump that fits my 09 JCW..... I'm guessing it's the same...
  19. Apok
    Apok New Member
    Jun 15, 2013
    776
    357
    Ah ha! There we go. This will be most helpful!
  20. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
