1st Gen R53 Cooper S OEM Coolant tank
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by Norm03s, May 29, 2012.
  1. Norm03s
    Norm03s New Member
    534
    Working at being retired.
    Somewhere in Sykesville. Md.
    My 03 coolant tank has developed the dreaded seam leak after almost 10 years. Is the revised OEM version prone to this issue, or is it a permanent fix?
  2. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
  3. Norm03s
    Norm03s New Member
    534
    Hungry vendor, needy customer meet on line.
    Order Number: 30118xxx, 17-13-7-529-273 Coolant Expansion Tank has shipped.
    Thank you!
  4. Dave.0
    Both of the OEM ones are crap and fail fail and fail again. They fail on BMWs and they fail on the MINI. Buy the aftermarket one made by Forge, it is made of steel and call it a day.
  5. Norm03s
    Norm03s New Member
    534
    You Know, I asked that exact question yesterday. If this SOB fails that is the last order they ever get from me.
    The vendor can only sell what MINI has. My tank has ben fine for 108,000 miles. If it goes FUBAR i'd have problem buying another oem one.
  7. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    We've seen many of the OEM tank fail, even the newer version. If you don't want it to fail go with the Forge Coolant tank, it is all Aluminum and won't fail again.
  8. ScottinBend
    Same with me Crash.......8.5 yrs and no problems with my OEM tank.
  9. Jan
    Jan Well-Known Member
    377
    382
    the problem with the Forge tank is: Has a stock cap that will leak and are prone to failure. Then your pretty tank looks like someone spent a night at the local bar and had about 10 too many
  10. Mr. Jim
    I put in the Forge unit last year, oem wasn't leaking after 6 years but piece of mind well worth it with the Forge.
  11. Way Motor Works
    206
    MINI Tuner
    Atlanta
  12. jiminni
    jiminni Well-Known Member
    262
    Ca.
  13. Jan
    377
    382
