2nd Gen R56 Cooper S Oh Oh........ R-56 Where Are You ???
Discussion in '2nd Generation: 2007+ R55 through R61' started by Metalman, Mar 20, 2011.
  1. Metalman
    Started up the MINI to take a spin around the neighborhood. Backed it out of the garage. No tach, no spedo, no lights on the dash. Fuses under the bonnet seem Ok. Not sure where the fuse is that handles the spedo and tach???
    Any ideas anyone?
    Sent from Arrakis, while harvesting spice, using Tapatalk when no one was looking.
  2. Justa Jim
    Fungo hasn't woken up from his long winters nap yet. Try again in May. :cornut:
  3. Jason Montague
    :cornut: I've been around here long enough to know that if weird dash board idiot lights start going off, and you're not on Psychedelic Drugs,CHECK THE BATTERY!!:Thumbsup:(just saying)
    Jason:popcorn::popcorn:
  4. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    Here is a local club members answer when his did something similar.
    I had a similar problem less than a month ago. The digital display kept cycling through all the different symbols, the speedometer and tac were stuck on zero, the wipers did not work and the parking lights would not go off with the auto headight switch on after I had cut the engine and left the car. I drove it to Flow and it was some type of module that they ordered and replaced under warranty. Of course, it cleared the ODB2 and I had to reset radio, keys etc.
  5. Metalman
    Thanks, going to the dealer to see what's up. I'm thinking a bad cell in the battery. The little window looks black and it should be green. But it very hard to see with a mirror. With only 6,500 miles, it's still under warranty.
    We'll see.
  6. BThayer23
    Random question about batteries while we're on the topic...
    New batteries in a newer BMW should be "registered" when installed so the computer knows it's got a fresh battery and will adjust its charge cycle. Does the MINI computer work the same way? I would expect the R53 doesn't, but the R56 might?
  7. Rixter
    Rixter Well-Known Member
    Jun 14, 2009
    1,230
    79
    Technology Architect
    North of the 49th
  8. Metalman
    Hmmmmm....
    It would seem so based on Ric's post.
    And thanks Ric, I'll at least be aware to see that the same or stronger battery is replaced if that is in fact the problem.
  9. Rixter
    Jun 14, 2009
    1,230
    79
    North of the 49th
    During the summer when Im on my bike way more than driving the MINI, I had the battery reset on me a couple of times due to drops in voltage. This summer I'm going to get a battery tender to keep it topped up at the right level.
    For cars with little usage a battery tender is a great thing....
  11. Justa Jim
    Something I don't need, as my car gets used. I now keep track of actual miles and virtual miles traveled. :lol:
  12. TGS91
    TGS91 New Member
    May 8, 2009
    1,593
    Sales Dude
    St. Louis, MO
    MM,
    Think Fungo is saying in not too subtle a way "DRIVE ME" :D
  13. Metalman
    You may have something there......
