2nd Gen R56 Cooper S Oil Dipstick
Discussion in '2nd Generation: 2007+ R55 through R61' started by genik, Aug 25, 2013.
  1. genik
    genik Member
    Feb 20, 2012
    402
    19
    Ok the stock oil dipstick is bad for checking oil, cant see where oil is on the oil mark, any solutions for an oil dipstick that is better?
  2. DneprDave
    I haven't had any problems with checking the oil with the stock dipstick, but I read complaints about it all the time. I check my oil cold, with the car on a level surface and always get consistent, accurate readings.
    Cravenspeed has dipsticks for both series one and series two MINIs that people think is much better than stock, but it is kind of expensive, in my opinion.
    I read that filing the dipstick flat on two sides makes it easier to read.
    Dave
  3. genik
    genik Member
    Feb 20, 2012
    402
    19
    Its true Cravenspeeds dipstick is kind of expensive, aren't there any other dipstick brands around?
  4. CHKMINI
    The Cravenspeed dipstick is well worth the money IMO. Easy to read and the red end cap adds horsepower....red always adds horsepower!
  5. Firebro17
    Agreed with the above! Get the Craven dipstick and you'll be a very happy camper. In my opinion there's no substitute.
    All you need is a paper towel & the right technique. Pull the stick wipe it off, reinsert, pull again & lay it down on the paper towel. The witness mark you left with the oil is the level. Imagine how many paper towels you could buy for $75. Although you will not have that so cool red handle to show off to friends & family. :smilewinkgrin:
  7. silky
    silky New Member
    Oct 12, 2009
    1,086
    51
    An even cheaper solution is to simply wait until your oil is so dirty that it's black and shows up well against the yellow plastic tip of the dipstick. On second thought maybe the paper towels is better.
  8. Scotty
    Scotty New Member
    Mar 9, 2013
    55
    25
    German/Swedish/Finnish marine propulsion equipment
    New Orleans
    I save on the paper towels. Usually I check my oil on weekends, in conjunction with yardwork. I use my finger instead of the towel and wipe off on sweaty shorts before showering! Honestly, you need to be really low or really high on the stick to mess up. Pump suction is at the bootom of the sump, and the crank recieves just as much splash at half a quart low.
    Crashton is right, however. Two dipstick pulls with the second pull on a white towel laying down as soon as you pull it.
  9. Firebro17
    It's really not about read'n the stick with a Craven. I've got piece of mind that it'll never wind up in the crankcase.....
    Yes that is possible of first gen MINIs. On the R56 & variants that dip stick is not going to break.
  11. Dave.0
    I am just glad to see people are checking their oil.
  12. Firebro17
    I didn't realize that. Thanks for the R56+ info.
  13. mrntd
    You could paint the handle red.
    I know a guy with some red plastidip. :ihih:
  15. Dave.0
    I have a red dipstick and I picked up 5 HP.
  16. silky
    silky New Member
    Oct 12, 2009
    1,086
    51
    (...must...not...reply...)
  17. Firebro17
    Only 5 HP? You'd better have that dyno guy get it recertified. I think me and my buddy each got an extra 7. :lol:
  18. Nathan
    He was using the "heartbreak" dyno at Helix.
  19. Tigger2011
    Tigger2011 Member
    Oct 30, 2013
    38
    25
    Fort Lauderdale, FL
    A very simple solution I urge every one to try at least once is this. Pull dipstick, wipe, reinsert but not all the way. Push it in until the bottom of the yellow plastic handle touches the top of the tube. Remove it and its very easy to read. Just remember to add 1/2 an inch.
  20. Grgramps
    Grgramps New Member
    11
    2010 R56 in which I changed oil for the first time. Previous changes were done by MINI in accordance with 3 year service.
    Now I understand why the dipstick was always so hard to read. The dealer overfilled so the level was above the top of the red plastic and I could never determine the level as shown on the steel shaft.
    When I refilled, I put in less than 4 quarts and it was easy to see on the red plastic (or whatever it is). As I added more oil there was no difficulty in reading the level as it read a bit higher with each addition of oil. Now it's at the top, but not overfilled.
    Problem solved!:wink:
