Engine Drivetrain 1st Gen Cooper S Oil issues
Discussion in 'Tuning and Performance' started by WolfGTI, Apr 15, 2010.
  1. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    So on my drive to work today - the oil light comes on for a sec. I stop check the oil level - it was a touch low - but nothing I would even worry about.
    After sitting all day the car starts fine no oil light, I pick up my daughter and I am literally 2 blocks from home when the light comes on and goes off again. I get home and check the oil level again, I add some oil to top it up.
    I take the car for a block and the oil light comes on permanently. So I get home, check the oil again - it is fine. I let the car sit for about 30 mins. I start it up again - no oil light, then after idling for about 4 mins the oil light is stuck on again.
    So is my oil pump going or is my oil pressure switch going? I am calling Eric @ Helix to discuss tomorrow.
    Any codes?
  3. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Sorry - I should have posted that.
    There are no codes - I checked twice.
    I'm going to take oil pressure sensor in the "Whats Bjorked" pool.
  5. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    A oil pump failure has no direct code
    Because you mention no engine noise specifically from the valve train....
    Nathan gets the guess the problem prize!!!
  6. WolfGTI
    May 21, 2009
    387
    217
    NJ
    There has been no change in the engine sound, I opened the hood and listened and there is no clattering or knocking. I really hope it's the sensor.
  7. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    The only other slight possibility would be if the oil filter mount assembly internal bypass valve was sticking. But this would be very rare?
  8. WolfGTI
    May 21, 2009
    387
    217
    NJ
    More or less rare than the oil pressure sensor ?? Are the sensors known to be a problem in our cars?
  9. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Ok - so I went to the dealer - bought a new sensor - $12.75. I also bought a couple oil filters and some oil while I was there.
    I changed the oil and filter. The car had not been started since yesterday @ 5pm. I drove it once I changed the oil. The total drive was approximately 4 miles. At mile 3 - the light flashes a couple times, then by the time I am on my street it goes solid. Again no change in sound in the motor, no increase in heat.
    I am really hoping it's the sensor - as it seems to occur after the oil has heated up - maybe the sensor thinks it has too little pressure? Anyways next up - sensor replacement.
  10. Metalman
    It sure sounds like the sensor is the problem. If you really had no oil pressure you would be telling us about a totally new noise coming from your bonnet.
    Along with some very unpleasant noises emanating from WolfGTI.
  12. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Just in case - I've already started looking at motors.
    What worries me is Dragon is barely 2 weeks away. I don't want this problem of oil lights hanging over me with a 16 hour drive looming.
  13. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Ok - changed the oil sensor today.
    After a 20 mile trip no light yet. Hopefully it is solved - I think my next mod is oil pressure and temp gauges.
    Thanks for the input.
  14. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Put another 50 miles on - no oil light - still keeping fingers crossed.
  15. Metalman
    Well here's your new problem. With all the work out you were giving that little oil light, make sure it didn't burn out. LOL
  16. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Nah - the light still lights if I put turn the key to the 'ON' position. It goes off once the car starts and oil starts to move.
  17. Dr Obnxs
    Dr Obnxs New Member
    Jun 11, 2009
    1,158
    Oil pressure switch failures
    are pretty common across all car platforms. At $12.75 they are making money on them, so they really are a cheap part. Typically they leak a bit or a spring or diaphram goes, and they fire at lower pressure than they should, then they permanantly go on the fritz.
    Matt
  18. WolfGTI
    May 21, 2009
    387
    217
    NJ
    Agreed - a cheep part and easy fix, it was just a little disconcerting having an oil light flash. I have owned several cars before this one (from being brand new) - both Japanese and European, a couple of them have gone past the 100,000 mile mark with me and one even went close to the 250,000 mark. I never experienced oil sensor failure before.
    That being said I still love the MINI. :D
  19. ScottinBend
    Glad this was an easy fix.
    Where is the sending unit located on the engine?
  20. Nitrominis
    Nitrominis Banned
    61
    Doing nothing
    Santa Cruz, CA
    It is located on the oil filter adapter. The best access to it is removing the passenger wheel and inner well. But small hands can get to it top side.
