Engine Drivetrain 1st Gen Cooper S Oil Leak near filter housing
Discussion in 'Tuning and Performance' started by Mike, Mar 8, 2011.
  1. Mike
    Mike New Member
    My '03 S has a small oil leak coming from somewhere near the filter housing. I've checked the base of the filter can where it screws into the housing, and I see no leak there (finger doesn't get oil on it).
    I suspect that the gasket between the filter housing and the block has started to leak. Has anyone else seen evidence of that? I've got a set of headers coming, and I'd like to take care of this oil leak at the same time. At least I'll get a good view of the leak with the subframe off of the car.
  2. k-huevo
    k-huevo Club Coordinator
    159
    Pipe Creek, Texas
    Have a look at the oil pressure switch, oil can weep from there and collect around the housing bottom bolt.
  3. Mike
    Mike New Member
    Ok, i'll give that a good look. I replaced the tensioner a year ago, wonder if the seal there could be leaking.
  4. k-huevo
    159
    Pipe Creek, Texas
    An example of a leak from the switch fitting.
  5. Mike
    Mike New Member
    Good pics, thanks. That's roughly the leak size I've got.
    Sent from my SCH-I500 using Tapatalk
  6. TATTRAT
    TATTRAT Well-Known Member
    496
    399
    Executive Chef
    NoVA/DC
    When is the last time you had an oil/filter change? Sometimes the ring on the filter can get crimped/over tightened and can leak.
  7. Mike
    Mike New Member
    I'd certainly like it to be that simple. The leak happened about 4000 miles after the last oil change, though, and there is no oil around the base of the filter can.
  8. minimark
    Not to take the thread off topic but you said you were installing a header and you could take a good look at this problem while the subframe was off. Are you removing the subframe to install the header or is there another problem or service you are doing?
  9. JCW03
    JCW03 New Member
    Nov 17, 2010
    14
    Marine Engineer
    Jupiter, Florida
    Great pics, I have a leak that looks worse than that, but that might be a good place to start looking. Anywhere else in that area that is a common for an oil leak ?
  10. k-huevo
    159
    Pipe Creek, Texas
    #10 k-huevo, Mar 9, 2011
    Valve cover, timing chain cover, and engine oil cooler.
  11. Mike
    Mike New Member
    Follow up: It appears that I have a leak past the oil pressure switch. I'll put on a new one and clean up the oil. In time I'll find out if there are any other leaks.
