Oil leak on 09 JCW Mini Cooper
Discussion in 'Starting Line - New Member Introductions' started by Jrucker, Apr 18, 2015.
  1. Jrucker
    Jrucker New Member
    Apr 18, 2015
    Good morning. Have just joined M A and excited to be able to learn more about my 2009 JCW Mini. Love the car but having some issues with an oil leak . John d.
  2. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    Welcome to the addiction. There is an old saying in England that "if a British car isn't leaking oil, it's out of oil". What size of leak do you have, and where? Do you have a small drop or two on the garage floor, or is the oil pan covered? Size and location of oil "stain" can tell you a lot. Someone to help will be along shortly.
  3. Metalman
    Two quick areas to look...
    An oil filter change can nick the "O" ring if not careful that can cause a leak...
    The changing of the oil filter can cause a small quantity of oil to leak out and then drip down the engine... A rag stuffed around the oil filter housing will catch this...
    The chain tensioner has also been found to loosen up, back out and start an oil leak... If it comes out you will have a gusher...
  5. Dave.0
    Welcome to M/A the FUN Mini site. :Thumbsup:
  6. 00Mini
    2,228
    Welcome to Motoring Alliance the onlyest MINI Forum you'll ever need !!
  7. MCS02
    6,278
    Welcome to MA!
