Oil leak on... exhaust??
Discussion in 'Classic Mini' started by ImagoX, Apr 6, 2015.
  1. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    Any of you vets have any idea where I could be leaking oil that would get all over the EXHAUST pipe? Newly-rebuilt engine from Seven... thought it was possibly from the rod change seal based on the drip pettern on the garage floor, but when I looked closer I noticed that while there *ARE* drips coming from that area there's also quite a bit of oil on the LCB and the exhaust pipe, all the way back to the cannister just about. I'm thinking that I may be leaking from the back-side of the engine somehow and it's hitting the LCB, then as I drive wind may be streaking the oil all along the pipe. Given the pipe being involved I'm thinking it's not the rod change seal, since that's not directly above any part of the exhaust, but... (((shrug)))).
    Thanks as always in advance! --M
    Valve cover gasket .......
  3. yellowbritishrocket
    May 16, 2009
    618
    277
    could be coming from a couple different places... could be the rocker cover gasket... could be the Tappet covers on the backside of the engine...or could be coming from the shift selector O-ring or the transmission...or...well it could be coming from any number of places because the wind will get in there and whip that oil backwards...i would turn the car over and let it run...check the oil pressure gauge to see if you are getting changes in pressure
  4. 00Mini
    2,227
    When you turn the car over won't create a bigger mess ?? :D
  5. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    I was thinking the exact same thing... :)
    If it stops smoking, by all means add more oil. :)
  7. BruceK
    BruceK Active Member
    Feb 24, 2015
    Texas
    Wow. I had the same problem on my Mini. I say "had" because it has magically disappeared. But I don't trust it is really fixed - just hiding is my guess.
    After getting back from the Mini Fun run to Arkansas last month, I found a nice collection of oil drippings on the garage floor. That really surprised me as it hadn't been leaking before that. But that was 1,300 miles of driving, including about 10 hours on the way home. I drove the car up on some ramps and tried to find the source. There was a mist of oil everywhere near the rear of the engine and on the exhaust and rod-change pieces too. It seemed to be coming from the differential where the left side drive shaft comes out. But, as I said, there was oil splattered everywhere in that area and it was difficult to tell with any certainty. I got some Dawn dish soap and sprayed a mixture of it all over the back of the engine and differential to try to clean up the mess.
    My first thought was to look at the shift rod seal, but that seemed to be dry(-ish). It could be the axle seal, but it could also be anything else in that General area based upon the oil coating, including the mechanical fuel pump seal. I am also wondering about excessive crank pressure due to the extended high speed running. I've got a breather on the timing chain cover and a breather on the flywheel cover and they are both plumbed to the carb in what appears to be correct the OEM way. So that looks to be fully sorted.
    Now the weird part is that since I cleaned the engine not a single drop of oil has fallen on the garage floor. So wherever the black gold was coming from before, it is not visible now.
    I drove a good 25 minutes on the highway each way to/from the local Cars & Coffee a couple of weeks ago. The oil got nice and warm, but there no leaks that I can see. Certainly nothing dripping to the ground. Strange...
    Hey, I'm not knocking it, I just don't really trust that it went away all on its own.
  8. Firebro17
    #8 Firebro17, Apr 14, 2015
    I'm guessing it's the rocker cover gasket... Look and see if it has a burnt space in the center on the firewall side. We've experienced this with the race car, created from a minor exhaust leak coming from center pipe on the header.
    Another thought... We also Yamabond the gasket to the cover and put a nice coating of grease on the head side to make for easy removal. No real leaks with that method, maybe just a slow seepage.... No issues though.
  9. DneprDave
    If you turn the car over it'll mess up the paint on the roof and the oil will drip on the inside of the hood.
  10. BruceK
    Feb 24, 2015
    Texas
    If it is a rocker cover gasket oil leak, there is also an alternative to the traditional cork gasket. Here is a link to one of the many suppliers of the silicone gasket. Gasket Valve Rocker Cover Silicone, Mini, Sprite,
  11. Minidave
    4,595
    I always had good luck with the OEM cork gaskets - I'd glue it on the valve cover, then put a good coat of grease on the other side, so I could remove it easily to adjust the valves - never had one leak like that.
  12. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    I ordered a new valve cover gasket and plan to attach it exactly like that, Minidave, yes. I did NOT order a rocker cover gasket, as I'm not sure where that port/plate is located... hmmm.
    I was under the car at the COMO event last weekend and it looks like it actually may be coming from the fuel pump. Rigt now the mechanical fuel pump is bolted to the block but is not being used - the diaphragm failed and started leaking fuel, and rather than replace it (again) I just hoked up an electrical fuel pump.
    I have a fuel pump blanking plate and fresh gaskets on order from Seven, but can someone tell me where the rocker cover(s) are located so I can eyeball them when I take the carbs off over the weekend?
    Thanks as always!!
  13. DneprDave
    I think you mean tappet cover, it is on the side of the block, on the intake/exhaust side of the engine. The intake and exhaust manifold have to come off to access it.
    The rockers are under the same cover as the valves right on top of the engine, so a valve cover and a rocker cover would be the same thing.
  14. BruceK
    Feb 24, 2015
    Texas
    But... Many Mini engines don't have tappet covers. In fact, it you have a non-Cooper S A-series big block "1300" engine, you have a solid wall block and there are no tappet covers. They are only on the smaller engines (850, 997, 998, 1071, 1100) and the true 1275 S.
    One less place to leak from.
  15. Minidave
    4,595
    Yep, I was surprised to see my engine did not have tappet covers - my 62 1100 had them.....
    It probably is leaking from the fuel pump gasket, that's not unusual.....your blanking plate will fix it.
  16. ImagoX
    ImagoX New Member
    Nov 1, 2010
    356
    104
    OK awesome... no tappet covers then for me. Thanks for clearing that up. Blanking plate and new gaskets arrived today and will be installed (hopefully) tomorrow in advance of Saturday's activities...
  17. Firebro17
    Rocker cover - Valve cover..... Semantics. The cover on top of the engine that covers the rockers.
    I believe you meant to say A+ blocks Bruce.
  18. Minidave
    4,595
    No he's rght, Pre-A blocks are like that too - mine is.
  19. Firebro17
    Ok. Learned something new today.
  20. BruceK
    Feb 24, 2015
    Texas
    Yes, Dave is absolutely right that I am right. :biggrin5:
