1st Gen R53 Cooper S Oil Pan drain plug washer size
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by ScottinBend, Jan 11, 2015.
  1. ScottinBend
    So.....I need some more and can't remember the size.
    Scott I just buy them a 1/2 dozen at a time at the dealer when I pick up oil filters.
  3. ScottinBend
    No local dealer.
    And I forgot to add that I have the oil temp sending unit drain plug.....so no rubber washer. I like to change out the washer at each oil change.
  4. Dave.0
    Ahhhh I see, maybe eMINIParts can hook you up on Momday.
    I use a magnetic drain plug (never know when I'll have to check my roof for aluminum). I carried the drain plug into the parts store & the nice guy behind the counter said "is 15 enough Chuck?" Yep it was & is.
    Scott if I remember correctly the drain plug is 14mm.
  6. MCS02
    Its the size that fits past the threads but not the head. That is the one I believe works best.:D
  7. TheModFather
    Sounds like it was spoken by a true mechanic! :)
  8. ScottinBend
    Bunch of frikkin' comedians we got here.........
    I would take the oem plug IF I can find the damn thing.....:p
  9. MCS02
    If you can't find it how are you keeping the oil in? Wait I know 50w and duct tape.:D
    Have you looked to see if it's screwed into the oil pan? That's where I keep mine.
  10. Nathan
    It's this big...
  11. TheModFather
    Wow, we are a bunch of comideans! But if it helps...
    We know the head of the drain bolt is 13mm (Actually it is NOT, it's a 1/2" = 12.7mm, because Chrysler design), and we have a semi disturbing picture of where Nathan keeps his drain plug.
    So with that, the warsher should be around 11mm ~ 7/16... ;)
  12. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
  13. MCS02
    eMINIparts to the rescue!:D
  14. ScottinBend
    Thanks MF.......
    I think I remember where I put the OEM plug, it's buried in a box after my last garage clean-up/organizing campaign.
    And MCS02.....I have the OEM oil temp plug which replaced the regular plug, and it has a standard washer instead of the built in rubber one.
