R56 Oil Pressure notification/flashing traction light
Discussion in '2nd Generation: 2007+ R55 through R61' started by ChItalian1027, Jul 1, 2019.
  1. ChItalian1027
    ChItalian1027 Member
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    Alright M/A so I’m getting an oil pressure notification randomly saying I have to take the car in to the nearest MINI dealer to get looked at, which is fine because I need to get my brake fluid serviced also. So what could that mean since I got the oil changed in April. Now the second part, I was driving home from work on the highway taking the same route I always do and the traction control light on the tach started flashing as I was taking a turn, I didn’t feel any lose of traction. The tires have 5/32, and I check the tread daily. So I’m not entirely sure what is going on. Any help or advice?
    How many miles on your car?
    Not to be a smart arse, but have you checked your oil? Lately?
    You may not have sensed a lack of traction, but it is possible the traction nanny did.
  4. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    @Dave.0 43K
    @Crashton I have and it's at the normal level. I'm looking into getting some new tires for my car right now, thinking of getting some Michelin Pilot Super Sports.
  5. Dave.0
    It might be time for a carbon blasting
  6. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    @Dave.O damn I was hoping it wouldn’t be that time already I was hoping it would go until 100k miles.
  7. MCS02
    Is your mini an S? if so @Dave.0 is correct about the carbon. I know on my R53 if I am in a corner and hit a bump some times I get a traction control light or coming out of a drive way. But you could also have a ABS sensor going bad.
  8. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    @MCS02 2013 MCS with 43k miles. Strange thing is this turn is an off ramp with no bumps because they just repaved the road last year due to all the pot holes. It’s a long sweeper and then goes straight.
  9. Dave.0
    100K. Hahahaha. Not a chance you have a DI (direct injection) motor with no fuel cleaning the back of the valves.
  10. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    Are you saying a symptom of the car needing carbon blasting is the oil pressure light?
  11. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    @Dave.O lol I was hoping to squeeze a few more miles.
    So I got the oil notification just now it says “engine oil pressure is low, consult a MINI dealer”. Asked the Indiana Motor Club for recommendations on shops that do carbon blasting. One thing I heard is that an oil catch can won’t stop the carbon build up but will slow it down along with doing an oil change every 3k miles. So I’m going to be changing my oil change intervals from 6k to 3k.
    No one has shown proof that oil catch cans do any good. DI engines are great for efficiency, but de-carboning them is something the car makers never mention.
    It's really troubling about your low oil pressure warning. I hope it's a bed sensor or some such.
  13. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    @Crashton it is a little unnerving for me to have it pop up randomly like this. I’m hoping it’s just a bad sensor.
  14. MCS02
    I have proof but I am not showing anyone!:Vomit:
  15. MCS02
    Turbos are hard on oil! I change my oil every 3k. I Have noticed on my wife's R57 and my R58 the oil does get more dirty. I don't know if the carbon issue would cause the oil light but if you followed MINI's long oil change intervals then it may be causing problems. Perhaps the screen is got some crud on it causing bad suction at low RPM. Remember they had to replace a few engines before the shortened the interval.
    Here is a great read on the N14 carbon problem and what to do about it.
    http://jmtcperformance.com/tech-info-and-help/mini-cooper-engine-n14-weak-piston-issue-myth/
    N14 Its an awesome motor! She just a little dirty
    Everyone should have an N14, it teaches patients.:D
  16. MCS02
    IDK perhaps it is sensing some slip. Any suspension Mods?
  17. ChItalian1027
    Sep 17, 2012
    108
    24
    IT
    Westfield, IN
    @MCS02 completely stock right now.
