1st Gen R53 Cooper S Ok I'm stupid and need help!!
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by MCS02, Apr 18, 2015.
  1. MCS02
    So I have been up sense 1:30 AM, maybe I should not have tried to work on my friends mini. I still have a lot to do.
    Heres my problem.
    Put a new clutch in it and today I put the new slave cylinder on it. I pressure pled it till no bubbles came out. But still a limp clutch. So my son helped with the stomp method, still not working. its better but it does not engage till half way down. I have gone through enough fluid to bleed the hole brake system. WHAT AM I DOING WRONG????
    So I moved on to the SC pulley. I used a three prong gear puller on it. No it did not budge!! It just bent the lip of the pulley. I only have Tuesday and Wednesday of next week to work on it. Any ideas what kind of puller would work? I don't know if I have time to get one shipped to me.
    I may call Detroit Tuned and see if they have a loner and pay to over night it but I really would like to find something here so I could get it done.
    I'm tired and can't thank straight and this big white rabbit won't leave me alone.
  2. Texchappy
    Texchappy New Member
    Mar 31, 2015
    27
    Retired U.S. Army Chaplain
    On the Caprock, off my rocker, on the South Plains
    Can't help you but fingers crossed. If you work on a car eventually you'll get where you're at -hope it's something simple on the clutch.
  3. Metalman
    [ame="https://www.youtube.com/watch?v=5bGvv2VUP_8"]Hossenfeffer! - YouTube[/ame]
  5. MCS02
    Yea I did compress it. Thanks for the thread link Metalman I will try that method and see it that works.
    Also after 20 min. of sleep I'm thinking about taking my drimel and cutting the pulley off.
    I leave tomorrow so I can't do it till Tuesday when I get home
  6. myles2go
    myles2go Active Member
    May 7, 2012
    589
    223
    collecting a paycheck
    WI
    #6 myles2go, Apr 18, 2015
    I hate to even say the name, but for the pulley, I like the alta tool that clamps around the pulley. Can't recomend anything else from them.
  7. Minidave
    4,592
    I don't, I found it difficult to use when the SC is in the car, the one from Craven Speed is much more user friendly IMHO.
  8. myles2go
    May 7, 2012
    589
    223
    WI
    For a pulley that is stuck, the tools that clamp around the pulley work well.
  9. chuckt
    chuckt New Member
    Oct 16, 2009
    19
    We had to heat my pulley with MAP gas to get it to budge... also using the wrap around style puller.
  10. ZippyNH
    #10 ZippyNH, Apr 19, 2015
    The low-profile craven puller MIGHT fit...are you 100% sure it is a stock s and not a JCW..very few JCW pullers are around....
    BUT if you bent the pulley on the car....it most likely will not...
    The puller is AN EXACT NEGATIVE of the factory pulley....
    The craven wil still need a pretty good portion of the pulley to be 100% normal shaped...
    If you distorted it...
    IMO time to cut it off...
    As for bleeding...have not done it (thank god), but have heard many folks who left it compressed overnight...then did it again....
    One thing that MIGHT be worth trying...
    Dot4 is pretty thin...dot3 is thicker...maybe use dot3 for the bleed...then run some dot4 when done...thicker fluid, might move the bubbles better....just reaching here...but might be worth it if you have a bottle on the shelf....
  11. cct1
    Whew....I read your thread title and figured it was a twelve step program for stupidity, and maybe we were all in line for a discount or something.
  12. BlimeyCabrio
    It took me and Wellzy a couple of hours of trying to get my slave bled completely. And he knew what he was doing. It's a nightmare. You need to hold it at the right orientation, and tap on it with a wrench or something, while doing the stomp method. And have the proper tool to compress it. I hope I never have to screw with it again. Geesh.
  13. MCS02
    Thanks everyone! I just hope I can get the stupid slave to work! I hate to cut the pull off but I think this may be the safest corse of action. It was rusty so I sprayed it with WD40 before I left. I will try agin Tuesday when I get home.
  14. MCS02
    double post I am repeating my self:(
  15. loftygoals
    loftygoals New Member
    Apr 20, 2015
    Mechanic and/or Tech Executive
    Dallas, TX
    I've been in your spot with my build. I had a clutch pedal that just wasn't right. I bled it a 1000 times, replaced it twice, and nothing seemed to work. It turned out it was a bad through out bearing. Hoping that isn't the case with yours, there is something that seems to really help:
    Take a board and rod and wedge it between the seat and pedal to full depress the clutch pedal. Leave it depressed for 12-24 hours. This makes my clutch remarkable more firm every time I do it.
    As for the pulley--they are a pain. I had to pull a JCW pulley of my replacement supercharger. I ended up cutting it off with a cut off wheel and a dremmel. It is a time consuming process, but it does work.
    -bj
  16. Code3_Mini
    Code3_Mini New Member
    May 8, 2014
    411
    299
    Full-time Military, part-time headbanger
    Sacramento, CA
    I've also found that C4 works in a pinch...as long as his insurance is current...
  17. MCS02
    I remember Alfas slave cylinder were a pain too. We found if you filled up the slave with fluid before you put it on that would help. I thought about doing that before I put it on, wish I had.:mad2:
  18. Rocco8788
    Rocco8788 New Member
    Feb 19, 2012
    41
    Pittsburgh, PA
    when I did my pulley on the SC I actually pulled the SC off of the car and had to use a press with a S!@# ton or pressure on it to remove the pulley after I did the same as you and bent the pulley. If you do cut it off just careful not to nick the shaft. as that may make for an ill fitting 15% pulley. (or which ever you are using)
    P.S if you do pull it off it's a good time to freshen the oil in the reservoirs to keep the SC working for years to come. I did this at 85K and they were almost empty.
  19. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    MSC02 where are you located? I have a craven puller sitting on my shelf my friend has been trying to sell (might be able to make you a good deal). What clutch did you put in? I did my friends last weekend with a Valeo and had to pressure bleed it twice, first time was a dead pedal, second time still soft ish but engaging (I remember my valeo broke in and got firmer).
  20. MCS02
    I'm in Memphis (the home of the King and the only place for real BBQ). I am up agents time. I want to get it done before I leave for the Dragon, and I still have my car and my sons car to go through. So I am about to start cutting. U am going to cut half way back then try the puller before I go all the way.
    I put a Valeo in it. I left the old master cylinder on it so I would know the clutch was ok before I did the slave.
