Suspension Brakes 1st Gen One word on Monroe Strut Mounts: DON'T!
Discussion in 'Tuning and Performance' started by DixonL2, Jun 24, 2014.
  1. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    Purchased (4) of these when I updated the suspension on the (2) R53's on our household. Installed them carefully and properly.
    The rubber separated on (3) of them within 1500 miles, (1) of them within 500 miles... and they're not warranteed. Waste of funds and (my) labor. Noted that the steel-rubber bonding surface was rusted when they separated. Clearly the quality just isn't there.
    Buyer beware.
    Sorry but I did not know Monroe was still in business. :rolleyes:
  3. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    The father of one of our apprentices works at the Monroe, MI, facility. This is, I believe, just a head office/R&D/test facility, and all of the production is done overseas.
    Thanks for the heads up. I'd say oem or IE fixed plates. The IE plates are beefy.
    eMINIparts.com can get you the oem pdq.
  5. DixonL2
    DixonL2 New Member
    274
    IE fixed are beefy, but you need to be sure your chassis is aligned (camber) before installing. IE adjustables require some "finesse-ing" and maintenance to make work well, but I got a set cheap and am using them successfully. I now have some OE's lying in wait, just in case.
