Engine Drivetrain 1st Gen Cooper S Output Shaft Bellow Repair
Discussion in 'Tuning and Performance' started by M^Cubed, Oct 11, 2010.
  1. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    My inner bellow on the passenger side has developed a tear. I've repaired it like a bicycle tire with a patch, but essentially it is going to need to be replaced. Should I just repair the inner bellow or should I repair the outer as well?
    Anythings I should know about repairing the inner?
    Thanks.
    If you are talking about the CV boots I'd replace them both. Also look very closely at the joint. If it lost a lot of its grease & ingested a lot of dirt it may not be long for this world.
  3. istara
    istara New Member
    May 21, 2009
    90
    Tucson, AZ
    You have to remove the outer to do the inner anyway, so may as well do both. I just did this on both sides. A vice was essential and I needed a very large hammer and a couple of beers to get everything apart initially. If it's the driver's side, then the c-clips are a pain, but otherwise it's not too bad a job.
  4. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Why is the just-a cooper bellow so much cheaper?
  5. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    One other question - has anyone used the EMPI and GKN Loebro replacements which are over $30.00 off each replacement?
  6. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    I've got the kits for the boots for $60
  7. M^Cubed
    M^Cubed Member
    May 24, 2009
    315
    12
    Way - thank you for the reply.
    I've found the Inner boot kit for about $55.00-$75.00 using the MINI branded parts and I have found the Outer boot kit for the same price using the MINI brand parts as well, BUT I have found the Outer kit from GKN Loebro for $9.25 with all the same parts and grease - they are an OEM supplier. The Inner kit can be had from EMPI for $13.75, but they don't stock them.
    Bottom of the page here
    MINI Cooper - Axles & Bearings - Page 1
