1st Gen R53 Cooper S Overloaded R53
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by west7, Apr 30, 2013.
  1. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    Recently I have had to haul 4 full grow adults around in my r53. In doing so I've noticed the rear sits much lower(when loaded) and the handling characteristics have changes quite a bit. With a total load of 640+_lbs(4 people), and the manual stating a max load of less than 500lbs, I've wonder if this is too hard on my MINI...... Any thoughts? Are there better shocks or cool overs better designed to handle the extra load? Is it simply a bad idea to haul that many people/much weight in my MINI?
  2. Jason Montague
    :cornut: I've never had occasion to haul that much weight in Margi(08 R56 BRG MCS/JCWm) so no help here but this will be a bump to keep you at the top of the list. Common sense though tells me that only occasional short trips around town should be fine. 100mi on the highway at speed(now 75-85mph in TX) could certainly be a safety issue.:Thumbsup:
  3. rkw
    rkw Well-Known Member
    443
    ??? 2006 Owners Manual says cargo and luggage load capacity 816 lbs for the hardtop, 771 lbs for the convertible.
  4. BlimeyCabrio
    Yeah... if it was 500lbs... I'd be in deeeeeeeep poo.
  5. Metalman
    Mucher moar funner with just one in the MINI....:D
  6. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    Thanks for the bump Jason and that's what I was thinking!
  7. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    RKW/BlimeyCabrio, At some point i read something stating that it was set up for 150lbs per person in the front two seats, 150 lbs split between the rear seats and either 30 or 50lbs in the boot. I must have completely missed the part about 816 lbs max load. Thanks for the clarification. So it seems I may not have a problem after all.....
  8. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    I completely agree Metalman!
  9. BThayer23
    You can bump up the tire pressure a few pounds, that'll help. Stiffer springs, too, but the problem is most aftermarket springs lower the car, which is not what you want. I've hauled 6 people in the MINI on a few occasions where I was the only one sober enough to drive. It drives a little different, but it's not too bad.
  10. Dave.0
    You can put passengers in a Mini...... Who knew. :lol::lol::lol:
  11. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
    6 people in a mini! That's gotta be a record. Talk about a full ride!
  12. west7
    west7 Member
    Sep 17, 2011
    136
    17
    Indianapolis, IN
  13. Jason Montague
    :cornut: Reading his post it was better then that. One sober caring MINI driver and 5 sloshing friends in a MINI and no crashes or jail time. Good Story! :Thumbsup:
