1st Gen R53 Cooper S P1685 default code ?
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by HyprBlu, Mar 6, 2012.
  1. HyprBlu
    HyprBlu New Member
    On the way to work my 05 MCS lost all power. I pulled over and he restated just fine without any issues. The MINI drove like normal with no issues.
    I checked my Scangauge and it shows a P1685 error code.
    Does anyone know what this code is? I have my manual at the house but wanted to check before I drove the MINI any further.
    Thanks
    There is a full chart of all the codes here on Motoring Alliance.
    Link to Library Article.
    P1685 - Electronic Throttle Control Monitor Level 2/3 Clutch Torque Max Error
    As to what is the cause...I'm not sure, hopefully others will chime in with some things to check.
  3. HyprBlu
    HyprBlu New Member
    I just checked with my local MINI shop where I had a RMW tune done and he said with an ECU tune / cold weather, MINI's will occasionally throw the P1685 code.
    He said to clear the code and if it does not happen again not to be concerned.
    A friend also replied that he find the same answer when he searched the internet.
