1st Gen R53 Cooper S P2096
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by jeffster06, May 6, 2013.
  1. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    To start im beginning to think Broknsmurf hates going to MOTD, This may also be preemptive as I haven't been home long.
    To start I drove from Dallas, GA to Robinsville on tuesday (about 176 miles) without issues. I filled up at the shell in Robinsville (93 as always) and proceeded to Fontana where my car was parked for the rest of the day.
    Fast forward to the sunrise smokies run on Wednesday. My MINI is driving without issue. While we are cruising on 74 (around 60MPH) I get an SES light its a P2096 never had any weird blips studders or anything. Once we get to the visitors center at the smokies I clear the code with my scan gauge and the light remained off for the rest of the drive (through the smokies up through TN and back on the dragon)
    The next day on the brewery run I get the same light on 74 cruising at about 60 (seeing a trend here?)
    Long story short even after clearing the light it eventually comes back but it only seems to happen when im riding steady speeds which always tends to be in the 50-60 range.
    I have done searches on this code and it seems like there are multiple causes for it. unfortunately for me I have to do my emissions test in about 3 weeks so I need to figure this out.
    Before my trip I replaced my IC boots (a week before to be exact) I saw a thread where someone mentioned a replacing the boots remedied this code. I plan on redoing the job just in case maybe something isn't sitting right there.
    I also plan on checking the exhaust flange gasket because when I put my used borla on if I remember correctly I reused the factory gasket and maybe it is now leaking.
    Am I on the right path with my thinking here? or is it possible I am over thinking this all together and that maybe for some reason my MINI just doesn't like something about the gas in NC? I filled up this morning but still had 75miles left on my range and got the light on again on my ride into work.
    I have also read that this code is a hard code on several threads and that a special tool is needed to clear it. however when I clear the code with my scangauge the light will remain off for sometime until I get to moving at a steady 60, even then it is unpredictable on when it turns on. I did the ice cream run on Saturday and the light didn't turn on until I left Bryson city (after a fill up at shell if that helps)
    If you are still with me so far I apologize for the long post, just want to get as much info in as possible.
  3. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    Thanks Nathan I forgot to mention that. I pretty much did a mind dump creating this thread. Guess that detail got lost.
  4. MCS02
    This may not help. When I was on the Dragon last year I got this code. Chad from Detroit tuned cleared it for me. I believe he said this happens because of the elevation change. I live in flat lands. You could email him to make sure I remember correctly.
    I know this does the same thing as clearing the code but have you tried disconnecting the battery for more than ten min. This will also allow the ECU to adjust for the gas you have in the tank.
    Good luck.
  5. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    I briefly spoke with chad at the dragon he suggested not worrying about it. which I am trying to do, I just realized how soon I have to plug up to re up my registration and now I'm slightly worried. I tried doing the reset through the computer (key to on position etc) I guess I could try taking the battery cable off tonight. Perhaps I need to just see what this week brings before going too crazy.
  6. BlimeyCabrio
    I wouldn't worry much about it unless it recurs at home.
    Still on the original oxygen sensors? How many miles?
  7. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    It has happened a couple times now since I have been home. I still have the original sensor in there. I'm about to roll over to 124K
  8. MCS02
    I'm sooooo glad I dont have to go through inspection where I live. Try undoing the battery. If it is fuel related it can take a couple of tanks of gas to straighten out unless you undo the battery to let it reset. At least thats what I've been told.
    Good luck. I would like to know if you get it fixed.
  9. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    I will be sure to update once I see a ready state for my emissions (assuming I can keep the light off that long). I cleared the light from this morning before I went and got lunch, I'm hoping I can make the drive home without seeing it and maybe the gas from this morning solved my problem (could be wishful thinking).
  10. Dave.0
    Find someone with a BavTech tool and have them clear the code and reset all the adaptive's. I had this same issuer at the dragon and I have the Bavtech tool and cleared them and reset them. All is good now. Elevation and different fuel (no ethanol & race fuel) causes his issue. If you do nothing for a tank of two the code should clear itself when your fuels system gets back to normal.
  11. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    This is what I'm hoping for Dave, the ride home from work I didn't get the light on so I won't be playing with Broknsmurf tonight. I guess I will just wait it out and see what happens. If this does end up being a fuel/elevation related issue I am curious as to why this year my MINI didn't like it, age/mileage maybe?
  12. BlimeyCabrio
    If someone has AutoEnginuity with the BMW extensions, they can clear the adaptations also, like with BavTech.
    Combination of fuel and altitude changes and the ECU adaptations can definitely make strange things happen.
    But at your mileage, you're also about due for O2 sensors. Does that mean they're shot? No, not necessarily. But they DO have a finite reliable life, and they DO get flakier the longer you run them past 100K or so. Not saying this is causing your problem now... but anytime I see any O2-sensor related codes on a car with old sensors, I always consider that they may at least be "contributing" to the issue, if not "causing" it.
    Some folks have post-cat O2 simulators to resolve various flaky post-cat issues. I personally replaced my remaining O2 sensor(s) at about 125k miles as a preventative measure, and seem to have fewer codes thrown since I did.
  13. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    If it ended up being the post o2 I would most likely go the way of a simulator, mainly because I eventually intend to buy a header and go catless. I plan on reving at every prius I drive by so they can hear me undoing their work :wink:
  14. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    well as of this evening my MINI passed emissions. I have yet to do anything to it either. I had a code this morning, so I did a computer reset (through the odometer) then cleared the code. I found a thread on how the drive cycle processes so I figured I would attempt to drive the car in a way that the tests would be able to complete. about half way from home I checked the readiness and it said ready. I figured what the hell lets see if I pass, and it did :Thumbsup:
    I have a strange feeling this isn't the last time ill see the P2096 code as I was driving my mini in a very spirited/aggressive manner just to keep the code from coming on, instead of cruising at around 2400rpm in 6th I left it in 5th gear which kept the RPMs up. I am just relieved now though that I will be able to get my registration renewed and if the code persists I have more time to deal with it. I plan on keeping this thread updated as time progresses.
  15. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    Just wanted to do a final update. I guess I made this thread to soon after I got home. It seems once I got some gas or even just drive time out of the mountains the light continues to stay off. Either that or Broknsmurf is done messing with me cause I passed emissions. I will have to see what this time next year brings.
  16. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    Got this code yesterday, Mini seems to be running fine, just concerns me because it says running lean. I am wondering if its just time for a new sensor I am at about 90k.
  17. Dave.0
    I would say yes at 90 k and I would only get the OEM one. You can find them cheaper than the dealer now.:Thumbsup:
  18. jeffster06
    Apr 23, 2010
    420
    111
    Dallas, GA
    I've been dealing with this code for the past year now, I kinda just don't pay attention to the light anymore. I just replaced both the manifold and cat gaskets as they were obviously leaking, no luck code came back. The odd thing is if I clear the code and drive the car hard.. constantly keep the revs all over the place I can get the ECU to go into ready status (so I know I can get my emissions to pass). If I had to guess the O2 sensor is probably dead, I'm at 136K now on what I think is the original sensor.
