2nd Gen Coupe P2187 code
Discussion in '2nd Generation: 2007+ R55 through R61' started by vetteguy4life, Jun 22, 2016.
  1. vetteguy4life
    vetteguy4life New Member
    Jun 21, 2016
    2009 base coupe.
    Poor idle when hot. Mpg's falling. New oil, 4 Oz seafoam in crankcase, bottle of techroline in tank with 12 gals of 93 octane. I removed pcv hose but there is no pcv valve or is it under valve cover as some of these threads explain. What would be next step. Car has 95k miles. KBB is probably 5500 so not worth 2k repairs as some posts have suggested. Tha k you.
    Have you ever had the carbon removed? FYI Searoam does not do *****.
  3. MCS02
    welcome to MA!
  4. MelloCooper
    MelloCooper New Member
    Jun 18, 2016
    33
    Plumber
    Mount Washington, KY
    What do you recommend besides seafoam?
  5. Dave.0
    Carbon blasting
    Detroit Tuned and Helix both offer the service.
    Maintenance: Any type of service work. Need an oil change? How about a brake bleed? Carbon Blasting? Maybe you just need a new air filter. We can help.
    http://www.detroittuned.com/shop-services/
  6. 00Mini
    Couldn't there be a problem with fuel distribution or O2 sensor ??
  7. MCS02
    If it is carbon build up cleaners will not work.
