2nd Gen R60 Countryman P2C57 CEL??
Discussion in '2nd Generation: 2007+ R55 through R61' started by wzabrouski, Nov 12, 2014.
  1. wzabrouski
    wzabrouski Active Member
    32
    Executive Director
    Keller, TX
    I have been hunting this code down for over a month now and have not been able to figure it out. I read on a BMW site, it was due to a leak with the air charge pipe. I have an aftermarket silicone air charge pipe and don't think that is causing a leak. This past weekend I checked all of the intercooler clamps and everything was tight. I am currently running the HFS-4 with a tune on my N18 in addition to an aftermarket intercooler, downpipe and a bunch of other mods. Has anyone had any experience with this code. I have searched and found zero results. I have attached a photo of the specs from the program I am using to read the codes. Any help would be greatly appreciated.
    PS - The interesting part is when the CEL is triggered I am always cruising on the highway and when I go to accelerate to pass someone, that's when the light is always triggered. No other time.
    6,321
    If you still have the stock air charge pipe I would put it back on and see if this fixes the problem. I would be very suspicious of the silicone pipe.
    It make sense to me that it triggers under acceleration, this is when it is on boost.
  3. wzabrouski
    32
    Executive Director
    Keller, TX
    I had the same issue before the air charge pipe was replaced. I really don't think it has anything to do with me changing that out.
  4. MCS02
    6,321
    Ok then I would not change it ether.
