Phone mount, I found a solution finally!
Discussion in 'Mid-Ohio Motoring' started by mergemini, Jan 28, 2013.
  1. mergemini
    mergemini New Member
    Nov 11, 2010
    304
    72
    Creative Director
    Latest stop, Columbus, OH
    I have been contemplating the overpriced Mini phone mounts since the day I bought my car. $99 for a solution? Could never bring myself to it as it seemed quite excessive to spend that on a mount that is vehicle specific.
    I just purchased and received the Mountek CD Slot mount. It is AWESOME! And even better, it was only $20 shipped!!! Great mounting position, very sturdy, works with the stock Y cable, and is almost perfect. Now if Mini has a software upgrade for iOS 6 that will allow me to control my track changes from the steering wheel, it just might be perfect.
  2. CHKMINI
    Jason.....you snap a photo at 70+ mph??? The Powell Police are coming to visit you :)
  3. mergemini
    Nov 11, 2010
    304
    72
    Creative Director
    HA! leave it to to you to not overlook the details. Cruising at 70 in a Mini is like a Sunday drive.
  4. Pretje
    Pretje New Member
    Jan 29, 2013
    20
    21
    Colorado
    Just ordered one from Amazon after seeing it elsewhere and searching for a decent solution for weeks now. Nice to see how it fits in a MINI.
    I assume the white adapter is a 30-pin --> Thunderbolt? I'm hoping the stock cable reaches the bottom of my iPhone 4 while contained in this thing...
    Not sure the track change issue is iOS 6, though... Running it on my iPhone 4 and track change works fine from the steering wheel.
    Thanks for the photo!
  5. old81
    This looks usable, is it tight and strong enough to use on the track for lapping days, I am thinking iPhone running rev being loaded up by my kiwi wifi.
    Hummmm, guess I will have to try it out.
  6. old81
    Just ordered off Amazon, prime saves shipping so about the same cost as direct. :)
    I will answer my on question, next Mountain drive.
    Anyone have a link to this fine device?
  8. old81
    Goggle search, first two hits are amazon the mountek.
    Sorry, buffer had wrong Cut/paste, this should work now. :) :(
    :) Don
    Thanks Don! :)
  10. Nathan
  11. Gil-galad
    Gil-galad Club Coordinator
    May 19, 2009
    1,178
    431
    Decorah, IA
    Don and Jason, am curious as to how much "vertical bounce" you get with this on rough roads. IME, it's always been the biggest drawback of other phone mounts I've tried with supposedly clever mounting strategies. I'm wondering if the attached Y-cable actually helps mitigate this.
  12. mergemini
    Nov 11, 2010
    304
    72
    Creative Director
    I've used it for about a week now and it continues to impress. It is very sturdy with very little bounce or shake.
    The bottom "stand" is removable. I've removed it as it seemed to just get in that way. The phone still stays and does not move. Mine is a 30 pin to lightning adapter for my iPhone 5. Stock Y cables reaches just fine. The way the mount is built, it can also be installed "upside down" which would lower its stance a bit.
    Only issue I have is where the cable falls. I tend to almost grab it when I shift. Simple fix would be to tie it back a bit, but not a major concern.
  13. mergemini
    Nov 11, 2010
    304
    72
    Creative Director
    You are correct regarding ios 6 on a iphone 4. Maybe it's a 5 issue? Not a big deal now that I have this mount, but it would still be handy.
  14. old81
    Well, if you had posted earlier Nathan, I would have used your link. :)
    Gil, I will let you know if it bounces through turn 4 into 5 and down to 6. :)
  15. canucc00
    canucc00 New Member
    Jan 1, 2012
    22
    Gurnee, IL
    My wife and I have these for our MINIs. She uses it for her iPhone and I use it for my Garmin. Mine has the removable bottom holder so the GPS is more centered when holder is on its side. My wifes is a newer version with the bottom holder able to be folded in so you don't lose it like I did, both very stable. I've used mine for four months with daily GPS inputs and has not come loose yet. The cables I've zip tied to length and put in cubbie under switches, I have them plugged into a Monster 2 slot USB plug in the lighter. Great items.
  16. Justa Jim
    Doesn't that make it hard to play a CD? :D
  17. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    What's a CD...? :p
  18. Pretje
    Pretje New Member
    Jan 29, 2013
    20
    21
    Colorado
    After a couple of days, I'm able to report that I'm quite happy with it. I'm afraid to tighten it down too much, but "snug" is sufficient anyway it seems. I don't drive really rough roads, but stuff like speed bumps and drainage dips don't seem to bother it one bit.
    As another reported here, the factory audio cable is a tad bit in the way, and I tend to run into it with my hand. Not too difficult to just tuck away slightly. Rotating the connector around seems to put a nice "S" in the cable that makes that easy enough.
    Really like the end result...
  19. iwashmycar
    iwashmycar Active Member
    Jun 1, 2009
    881
    87
    architecture
  20. mergemini
    Nov 11, 2010
    304
    72
    Creative Director
