PlastiDip Durability....
Discussion in 'Detailing' started by moreorless, May 2, 2010.
  1. moreorless
    moreorless New Member
    Aug 17, 2009
    343
    14
    In a pile of sawdust.
    I'm going to be using a tow hook as the mount for my front license plate. The tow hook will be in place permanently, but the rest of the plate mounting apparatus will be stowed in the boot only to be used when required.
    So, I have two thoughts on covering the tow hook. The first thought is to use black ceramic caliper paint. The second thought is to use black PlastiDip Both are easily applied.
    What has your experience been with PlastiDip? Particularly where it will be exposed to all sorts of "stuff". Is it durable enough, or will I be touching it up on a frequent basis.
    The MINI is a daily driver at about 200 miles per 5 day period.
  2. ScottinBend
    That's a tough one.......I recently redid my aero front bumper "trim" with Plasti-dip spray and it has held up a whole heck of a lot better than the original textured trim spray did. But it is a "softer" base then the metal is. I really like it so far.
    Nice thing about it tho, is you can get it off very easily if it doesn't work out for you.
  3. imspencerwithanr53
    imspencerwithanr53 New Member
    May 27, 2009
    117
    Barista
    Portland, OR
    Plastidip will be good until you actually need to tow your car then it might rub off so that's the only thing you should worry about.
  4. BlimeyCabrio
    for tow hooks, using the traditional "dipped" plasti-dip works better. Puts a thick coating on the hook like on a pair of pliers. Will still get damaged when you actually use the hook for towing... but easy to peel off and re-dip.
  5. moreorless
    Aug 17, 2009
    343
    14
    "dipped".
    Well, that sets up a whole new set of questions. :skep:
    With the tow hook already installed, how am I going to pick up the entire car to dip the hook into the can. :frown2:
    Sheesh, of all the hairbrained ideas. :eek:ut:
  6. Wikedmini
    Wikedmini MINI of the Month - December 2009
    Aug 17, 2009
    304
    13
    i havent had problems... I use it all the time
    I "dipped" my hook.
    and i "Sprayed" my head light rings
    no problems what so ever
  7. moreorless
    Aug 17, 2009
    343
    14
    However, on second thought, I bet those two dudes with Nathan in that one picture could pick the MINI up and dip the hook.
    Mmmmm......"dipped" may not be a bad idea after all Blimey........
  8. BlimeyCabrio
    #8 BlimeyCabrio, May 4, 2010
    Hint: rotate the hook counter-clockwise.
    Or rotate the MINI counter-clockwise, while holding the hook stationary
    This makes dipping easier
  9. Angib
    This is exactly the reason Mini fit towing sockets front and rear - you borrow a friend's towing eye, screw that into the back and use that to hang your Mini from while dipping the front eye.
    I mean, this isn't rocket science, is it? :ihih:
    Andrew
  10. Metalman
    Hey............ Are you guys blonde? LOL
  11. moreorless
    Aug 17, 2009
    343
    14
    Excellent Idea!!:idea:
    I have a spare tow hook that I can use! :Thumbsup:
  12. Vernon29RW
    Vernon29RW New Member
    May 22, 2009
    115
    Pat-Med, NY
    I spray PlastiDipped my chrome gas door almost two years ago now and it still looks just like when I sprayed it. No chipping or peeling....PlastiDip FTW!!! I'm gonna be PlastiDipping my brothers front grill and door moulding strips on his white Jetta black sometime this summer. Great stuff, recommend it on anything!
    Steve
  13. howsoonisnow1985
    howsoonisnow1985 New Member
    Aug 8, 2009
    171
    Inmate
    Santa Cruz County Jail
    PlastiCoat the dipped version has lasted about 4 years in the rear so far and 3 in front I peeled it off and redipped it, seems to get dirtier in front. Oh and 2 tows on the oem red "dipped" tow hooks.
