Possible CVT Issues?? Heeeeeeellllp
Discussion in 'MINI' started by apitner, Jun 8, 2014.
  1. apitner
    apitner New Member
    Jun 8, 2014
    Tampa, FL
    A couple of months ago my old car was totaled (sigh) and I bought a 2005 MINI Cooper, automatic, with about 100k miles on it. Since then it has caused me a lot of trouble and cost me significantly more than expected. Today while I was leaving work I went to pull out of the parking lot and my car wouldn't go anywhere. It moved, but just barely enough to get me out into the middle of the street. I was able to drive it home but it seems like it isn't switching gears. It won't exceed 2500 rpm and doesn't want to go faster than 30ish mph. It's been kind of jerky since I got it but everyone said "Oh that's just how a CVT drives". Until now it's been worst when I put it in reverse and try to back out. For a second it seems like it won't move and then suddenly jerks back. Now it is basically un-drivable and I'm debating wether this would be covered under the tranny recall. There isn't a check engine light on, which would make me suspect a speed sensor, so I have absolutely no idea where to start. Any help would be much appreciated.
  2. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    #2 rum4, Jun 8, 2014
    Do you know when the fluid was changed last? Have you checked the battery? I read where if the battery is going bad that the transmission will act crazy. Read this copied from Mini
    We bought a*Mini*Cooper*with the famous CVT gearbox three years ago and it wasn't right from the start, but not having driven a Mini with a CVT we just thought it was the deficiencies of the system.
    The car was bought with just 14,000 miles on the clock, even though it was an '03 model. The car was slow to pull away, the delay from standstill to selecting the correct gear was a second or so.
    This continually got worse to a point where the car would pull away reasonably, but immediately the CVT would select a very low ratio (akin to 5th gear or so) and the acceleration was awful. Eventually we got the dreaded 'EP' and the car drove like a wheezy moped.
    I cleared the error codes (different each time) using INPA, and that got it going again for a few days - but it very quickly reverted to awful performance and another Emergency Program warning.
    We took it to BMW (Snows in Portsmouth) to get the gearbox oil changed as a first line of attack, and to have them diagnose what the problem was. They reported that the gearbox seemed fine after a 'gearbox reset' and the oil change. It took only a few miles before all the symptoms were back again.
    Something on the INPA diagnostics report caught my eye though, and that was the battery voltage which was 14.9V, which is much too high, especially at tick-over. I know that the reported battery voltage is not that accurate, but that was certainly wrong - I decided to replace the battery.
    And that cured all the problems! Although the car always started fine, the battery was failing. The car is now extremely lively, chooses the correct gears, pulls away quicker - in fact, it seems like a new car. The battery was changed over 5000 miles ago now and the CVT is working extremely well.
    So, if you have CVT problems, try changing the gearbox oil and your battery before giving up.
  3. MCS02
    6,317
    Also I think MINI extended the warranty. I can't remember but maybe someone els here will.
  4. rkw
    rkw Well-Known Member
    443
  5. MCS02
    6,317
    ^^^^^^^yep that's it^^^^^^^
