2nd Gen R56 Cooper S Power plug in the boot
Discussion in '2nd Generation: 2007+ R55 through R61' started by Ray737, Jul 28, 2012.
  1. Ray737
    Ray737 Member
    May 18, 2012
    32
    Hey everyone. I have had my 2012 cooper S 2 weeks now I am loving it. I just discovered there is a power outlet in the boot (had to look it up in the manual:). I noticed the "socket" protrudes out at an angle. Is this normal??? Seems like it would be just flush with the panel. Any thoughts??
  2. Metalman
    Any pictures?
  3. Ray737
    Ray737 Member
    May 18, 2012
    32
    I am currently out of the country. Will take a pic and post it tomorrow.
  4. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Hmm pictures would definitely be helpful. There is a normal cigarette lighter socket on the left side in my boot, is that what you a referring to?
  5. pmsummer
    pmsummer Well-Known Member
    Apr 3, 2012
    570
    400
    Semi-retired planner
    The one in my Clubman is flush.
  6. Ray737
    Ray737 Member
    May 18, 2012
    32
    Yes that's exactly what I am referring to
  7. pmsummer
    Apr 3, 2012
    570
    400
    I've noticed that a lot of the trim work in the MINI's isn't up to Japanese or American standards (sounds odd, but that's the standard now... the Yanks have gotten very good). If it doesn't just 'pop' back into place with a bit of pressure, add it to your list of warranty items.
  8. pmsummer
    Apr 3, 2012
    570
    400
    BTW: It was flush in the 2012 MINI loaner I had a couple of weeks ago.
  9. Ray737
    Ray737 Member
    May 18, 2012
    32
    Hey thanks pmsummer. I did try to push it in when I first notices it but it didn't budge at all. That's why I was wondering if that's the way it was supposed to be. Clearly I may have to visit the dealer this week to have this corrected.
    Thanks for the info guys.
  10. Ray737
    Ray737 Member
    May 18, 2012
    32
    This is what it looks like. Tried pushing it in. No luck ImageUploadedByTapatalk1343585158.088530.jpg
  11. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Take out the blank plug in the center and try pushing it in.
  12. pmsummer
    Apr 3, 2012
    570
    400
    In that pic, the socket looks fine (looks flush to me), but the "plug" doesn't seem to fit. What is that plug? Is that the socket cover that came with the car? Looks different.
  13. Ray737
    Ray737 Member
    May 18, 2012
    32
    Trust me it's not flush. This is the plug that came with the car
  14. pmsummer
    Apr 3, 2012
    570
    400
    When you take it back in for first service, just have your dealer take care of it. They'll probably have to pull the carpet, but that's what warranties are for. :)
  15. Ray737
    Ray737 Member
    May 18, 2012
    32
    Exactly. I will have them take care of it. It's a bit of an eye sore to me so I may take it in prior to my first service :)
  16. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    I have a '03 MCS that has a hole in the left pannel in the boot on the plastic pannel that is filled with a plastic plug. Would this be where the power point would go? Also how would I go about wiring one in? Would I just run a ground wire to a bolt or nut inside the pannel on the left that has my tow ring and a 10-13mm combination wrench and a screwdriver that flips from flat tip to phillips in the bag and a inline fuse to a hot on the positive side of the battery as it's in the boot, no spare have to use run flats. I have a small 12V air pump to fix a flat with some Slime in a emergency and if I could add a power point there it would be easy to reach the rears and the one by the cup holders up front could reach the fronts.
  17. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    Take the plastic plug out, plug in your 12v device in the socket and voila...Power!
  18. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    I thought that was what it was for and it should be pretty straight forward to wire.
  19. Gizmo
    Gizmo New Member
    May 22, 2012
    487
    283
    Flemington, NJ
    I was trying to say that you don't need to wire anything...the 12v socket should already be installed.
  20. ZippyNH
    +1
    should already be done from the factory.....mine was.
