Powerflex Transmission Mount Bushing Install W/ Upper Engine Damper Replacement
Discussion in 'Tip's, Tricks and How To Articles' started by MCS02, Jan 18, 2018.
  1. MCS02
    MCS02 submitted a new Article:
    Read more about this article here...
    • Informative Informative x 1
    Ummmm did you forget these are 100% better Lee ? o_O
    Vibra-Technics MINI Cooper S R53 ('02 - '08)
  3. MCS02
    Ha No I am moving over old how to from the old sight. When I do it it starts a thread. I thought I had stoped it from doing that. I guess not
  4. Dave.0
    Ahhhh no problem, keep up the good work.
    You know I see everything.
  5. agranger
    1,486
    Kind of funny that this thread popped up on my feed today. I wrote the article years ago and I'll be putting the VibraTechnics damper on my new R53 today or tomorrow, depending on how work goes.
  6. Sully
    Sully Administrator
    Jul 21, 2015
    2,100
    916
    Software
    30350
    @agranger - yea, we are working on manually converting the library over to articles.. there is some great stuff in there. I also "moved" it to you so it shows that you wrote it. You should also be able to "edit" it. With this system we will be able to also convert Articles to threads.. I.e if there is a really good informative thread, we can pull together the key post to make it article like.
