Pre-MOTD MINI Prep Checklist
Discussion in 'MINIs on the Dragon 11 (May 1 - 5, 2013) - TN / NC' started by Nathan, Feb 19, 2013.
    #1 Nathan, Feb 19, 2013
    Time for the annual occurrence of this checklist.
    It's a PDF, download and print if you like.
     Oil – Close to 5K mark on current Oil? Go for an early change.
     Under Bonnet Check –Look for leaks, broken/worn engine mounts, worn plug wires
     Gearbox Oil – If near 2 years or 50K miles - Change
     Brakes – Check Rotors and Pads – Have at least 50% left
     Brake Fluid – If near 1 year or 25K miles – Change
     Coolant – MINI recommends every 4 years from build date for a change, every 2 years would not hurt.
     Tires – Tread level should be at least ½, check for uneven wear
     Wheels – Check Torque on lugs 83ft/lb 1st gen, 102ft/lb 2nd gen – Check often on site. See Chad at Detroit Tuned tent to use his torque wrench.
     Wipers – Replace blades if older – It could be quite wet at MOTD
     Lights – Check all lights to verify operation
     Battery – good condition, make sure is securely fastened
     Suspension – Check all bushings for wear, replace as needed
     Steering – Check for wear – replace anything questionable
     Exhaust – Secure with no leaks, check mounts
     Wheel Bearings – Check for excessive play
    Running The Dragon even at the posted limit taxes all the systems on our MINIs. 311 Turns in rapid succession will find the weaknesses if not attended to ahead of time. Please be sure to check you braking system well.
    Check list compiled with the assistance of Chad from Detroit Tuned.
  2. DixonL2
    DixonL2 New Member
    274
    A bit north of the 'burgh, PA
    And don't forget to tighten that loose nut behind the wheel...
  3. BlimeyCabrio
    And refill the blinker fluid.
    And bring liquid smoke for your brakes.
  4. Stinker
    Stinker Active Member
    May 16, 2009
    237
    117
    USPS Maintenance Mech
    Smithfield, VA
    And a BIG horn for the HD riders.
  5. Dave.0
    Make sure you bring enough Meth and a blank credit card for lots of fuel.
  6. colinmini
    colinmini Well-Known Member
    441
    Leon, don't forget the Dragon Draggin' track, check. 100's of pounds of Dragon Bingo markers and cards, check. Keep Colin from doing stupid things, check!
  7. DixonL2
    DixonL2 New Member
    274
    Colin, there are things I CAN do, and things I cannot accomplish. You'll remember my sage advice when you said "That was GREAT! Let's sneak out for Just One More Run!"
    Whenever you say "...Just One More Run"... it's like saying "Hold my beer and watch this!". Nothing good happens after that... unless, perhaps, you're watching the budget of the State of Tennessee...
  8. jgc_tn
    jgc_tn New Member
    Apr 21, 2013
    39
    6
    SCII & MSWA & Fitness Instructor
    E TN
    I am going to be a 'duck out of water' at this event!!!:yesnod::yesnod::yesnod:
