Pre-MOTD MINI Prep Checklist
Discussion in 'MINIs on the Dragon 12 (April 30 - May 4, 2014) - ' started by Nathan, Mar 3, 2014.
    Time for the annual occurrence of this checklist.
    It's a PDF, download and print if you like.
     Oil – Close to 5K mark on current Oil? Go for an early change.
     Under Bonnet Check –Look for leaks, broken/worn engine mounts, worn plug wires
     Gearbox Oil – If near 2 years or 50K miles - Change
     Brakes – Check Rotors and Pads – Have at least 50% left
     Brake Fluid – If near 1 year or 25K miles – Change
     Coolant – MINI recommends every 4 years from build date for a change, every 2 years would not hurt.
     Tires – Tread level should be at least ½, check for uneven wear
     Wheels – Check Torque on lugs 83ft/lb 1st gen, 102ft/lb 2nd gen – Check often on site. See Chad at Detroit Tuned tent to use his torque wrench.
     Wipers – Replace blades if older – It could be quite wet at MOTD
     Lights – Check all lights to verify operation
     Battery – good condition, make sure is securely fastened
     Suspension – Check all bushings for wear, replace as needed
     Steering – Check for wear – replace anything questionable
     Exhaust – Secure with no leaks, check mounts
     Wheel Bearings – Check for excessive play
    Running The Dragon even at the posted limit taxes all the systems on our MINIs. 311 Turns in rapid succession will find the weaknesses if not attended to ahead of time. Please be sure to check you braking system well.
    Check list compiled with the assistance of Chad from Detroit Tuned.
    Exhaust - install much LOUDER one. :devil:
  3. rum4
    rum4 Club Coordinator
    4,568
    1,475
    SC
    Thanks Nathan.
  4. Dave.0
    Pack Beer.......:beer
  5. wmwny
    4,048
    2,246
    Don't bother bringing cigars...I'll bring more than enough for all who desire to partake....:Thumbsup:
  6. Jason Montague
    :cornut: Me Too!:Thumbsup:
  7. versus
    versus Active Member
    Sep 8, 2009
    553
    87
    Are there any accompanying videos/tutorials for the uninitiated to assist in knowing what to look for?
  8. Dave.0
    Like what?
  9. versus
    Sep 8, 2009
    553
    87
    Like anything. As simple as identifying worn wipers and replacing them to the more technical things. A lot of folks on here have no qualms about poking around an engine bay (or pulling an engine), but everyday is somebody's first day trying to tackle something. Just trying to make it easier on those inclined to get their hands dirty or learn something new.
  10. Dave.0
    Oh ok you are talking about prepping your car for the Dragon. (gotcha)
    I was going to say the Dragon is like Vegas, what happens at the Dragon stays at the Dragon. * unless you crash then it on YouTube FOREVER. :ihih::lol:
  11. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    F..k the beer.
    Pack lasagna!
  12. Dave.0
    You know I will bring 2 full dinners with a total of (4) Lasagna's.
    They will be in my front seat buddy. (Italian and Mexican)
    They will be made closer to the Dragon so they will be Fresh. :Thumbsup:
  13. Detroit Tuned
    319
    evertyhing
    Metro Detroit
    we should add put car back together to the list... :/
  14. ejwjcw
    ejwjcw Active Member
    202
    128
    Metro Denver
    :confused::confused:The story starts with driving home from work. I washed my car on the way home, pulled into the driveway, wiped down a couple more spots and spared Elson the sloppy road conditions for the weekend.
    Monday I prepared to venture to work with Elson and he would not start. He tried to turn over and just could not fully start. No odd sounds. Monday evening I worked with Mini roadside assistance to get the car to the dealer. Things did not work out in a timely fashion and the pickup was made on Wednesday. I figured since it was at the dealer I would have them perform Nathan's posted checklist. Thursday the dealer was able to look at the car.
    I was told by the rep that the reason the car would not start start was that it was flooded. I was told the battery had run low due to multiple door opening/closings on the previous Friday. The battery had run low and attempted starts had flooded the engine with fuel and would not egnite. The oil would now have to be changed to correct the issue.
    I am no car buff, but I feel the explanation is off base.
    Any direction would be helpful.
  15. Jason Montague
    :cornut: It does have that ring of BS/mumbo jumbo to it. I'm going to let some other MINIacs read this and see what they think.:Thumbsup:
  16. clifforddward
    clifforddward Active Member
    Dec 2, 2013
    104
    76
    Cary, North Carolina
    #16 clifforddward, Mar 8, 2014
    I don't know about anybody else, but here's a link to photo of work I'm doing to prep my Mini for this year's MOTD:
    https://www.dropbox.com/s/5tsgs4xfs3sswfp/IMG_0337.JPG
    This image was before I got into removing the head and header/exhaust...Hope she'll be ready in time!
    Best Regards,
    Cliff
  17. clifforddward
    Dec 2, 2013
    104
    76
    Reached a milestone this afternoon...finally got the last parts "pulled apart" and now starting the process of replacement and bolting everything back together. This evening's job was installing the Vibratecnics gearbox mount and torque link...tomorrow comes the gasket on the oil filter housing along with related parts in that portion of the engine bay....getting ready for bolt on of the JCW head I'll be installing over the weekend....I must admit it is MUCH more fun installing new parts than it was disassembling and cleaning old stuff!
  18. Nathan
    Cleaner too!
  19. Savvy
    List of parts ordered and inbound for install in the next week or so...
    1) H-Sport Adjustable Rear Lower control arms
    2) Power Grid Adjustable End Links (front and rear)
    3) Revalved BC coilovers (with Swift Spring upgrade)
    4) Bridgestone Potenza S04 Pole Positions (giving them a try this year, wasn't impressed with the Michelin Pilot Super Sports)
    5) Voltage Pedal set
    Need to order and install:
    6) Rotors and Pads (front and rear)
    and need to decide if I want to tackle vinyl wrapping my headlight rings myself... or drop them off at the local "dude" and let him do it, to replace my heinously chipped-up paint job from this past fall.
  20. Dave.0
    ^^^^ I hear the local "dude" is really good and cheap. :eek::ihih:
