Pre-MOTD MINI Prep Checklist
Discussion in 'MINIs on the Dragon 14 (May 11 - 15, 2016) Fontana' started by Nathan, Mar 28, 2016.
    Time for the annual occurrence of this checklist.
    It's a PDF, download and print if you like.
     Oil – Close to 5K mark on current Oil? Go for an early change.
     Under Bonnet Check –Look for leaks, broken/worn engine mounts, worn plug wires
     Gearbox Oil – If near 2 years or 50K miles - Change
     Brakes – Check Rotors and Pads – Have at least 50% left
     Brake Fluid – If near 1 year or 25K miles – Change
     Coolant – MINI recommends every 4 years from build date for a change, every 2 years would not hurt.
     Tires – Tread level should be at least ½, check for uneven wear
     Wheels – Check Torque on lugs 83ft/lb 1st gen, 102ft/lb 2nd gen – Check often on site. See Chad at Detroit Tuned tent to use his torque wrench.
     Wipers – Replace blades if older – It could be quite wet at MOTD
     Lights – Check all lights to verify operation
     Battery – good condition, make sure is securely fastened
     Suspension – Check all bushings for wear, replace as needed
     Steering – Check for wear – replace anything questionable
     Exhaust – Secure with no leaks, check mounts
     Wheel Bearings – Check for excessive play
    Running The Dragon even at the posted limit taxes all the systems on our MINIs. 311 Turns in rapid succession will find the weaknesses if not attended to ahead of time. Please be sure to check you braking system well.
    Check list compiled with the assistance of Chad from Detroit Tuned.
    Don't forget BEER or "drink of choice" because Graham Country is a dry county. :beer:Thumbsup:
  3. Goldsmithy
    Jan 30, 2015
    1,748
    982
    TCB
    Main Street in the land of Oz
    Extra underwear, lots and lots of extra underwear...:wink::biggrin5:
  4. yellowbritishrocket
    May 16, 2009
    618
    277
    and if you are driving a classic mini to said dragon... a container of spare parts and gaskets lol
  5. LowCountry S
    LowCountry S Active Member
    May 14, 2009
    128
    98
    ^^^this!! :cornut:^^^
    just did all my pre-trip stuff with the added bonus of a clutch, flywheel, assorted bearings and bushings, and a Quaife LSD--looking forward to the trip! :cool:
  6. jeffster06
    jeffster06 Active Member
    Apr 23, 2010
    420
    111
    Dallas, GA
    My pre trip inspection has been exhausting.... my R53 is no longer a daily driver but I had to drive it all last week due to the other ride being down. During this week, my exhaust fell apart and I discovered both my wheel bearings had excessive play :mad:
    So now I have a new exhaust system (even found a leak at my test pipe while I was under there) and new wheel bearings. Flushed the brake fluid while I was at it too, I believe Broknsmurf is now ready. I might throw an oil change in there too although im at like 2.5k on the change, except I did it last June-Julyish...
  7. LowCountry S
    May 14, 2009
    128
    98
    and now a motor mount before I go....(sigh)....
  8. vetsvette
    In my case... Cash money for Vendors Row! :drool
  9. yellowbritishrocket
    May 16, 2009
    618
    277
    in my case lots of old 1st gen parts for the sale table
  10. Zillon
    Zillon Well-Known Member
    Jul 12, 2014
    702
    632
    Central NJ
    Mine is coming together nicely.
    New brakes, suspension, tires, rear sway, fluids...
  11. LowCountry S
    May 14, 2009
    128
    98
    motor and trans mounts done...swap wheels are good to go!
    :D
  12. WolfGTI
    WolfGTI Active Member
    May 21, 2009
    387
    217
    NJ
    Some guys have all the luck.
  13. Zillon
    Jul 12, 2014
    702
    632
    Central NJ
    No luck on the mega-build?
  14. agranger
    I know.... It isn't car prep, but bring lots of layers (weather up there changes faster than Nathan's tires), some sun screen and bug repellant.
