Engine Drivetrain 1st Gen Cooper S PRW Damper Removal Help
Discussion in 'Tuning and Performance' started by GeorgeCo, May 12, 2015.
  1. GeorgeCo
    GeorgeCo Site Sponsor
    Motoring Alliance Sponsor Supporting Member
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    #1 GeorgeCo, May 12, 2015
    I need to pull a PRW harmonic damper off of the crank of a R53. I can't find a puller tool with a bolt circle big enough to fit. Looking online for a tool, the size of the bolt plate is never given. Anyone know of a tool that fits? The distance between two holes (one side of the triangle) is about 3 5/8 in. Most universal tools go up to about 3 1/4 in.
  2. Jason Montague
    :cornut: You might send a PM to eMINIparts. They are always helpful. :Thumbsup:
  3. eMINIparts
    eMINIparts Well-Known Member
    3,751
    1,087
    MINI Parts Advisor
    Bedford NH
    I can get this tool for you. $63.92 plus shipping.
  4. Dave.0
    Send a PM to Jan or Colin Greene and they will be able to help you as they sell those dampers.
  5. ColinGreene
    ColinGreene Well-Known Member
    438
    293
    Orange county Ca
    I dont think what E mini parts will sell you is what you need since this is a non stock damper.
    Why are you removing it?
    What the engine shop did was take some aluminum stock and build a adapter that bolts to the damper and has the smaller bolt pattern on it to be able to pull the crank damper off.
    thats what you need.
  6. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    I found someone with one to borrow, but if that doesn't work I might see about having an adapter plate fabricated. Thanks for the idea.
  7. ColinGreene
    438
    293
    Orange county Ca
    I still dont understand why you need to pull it off i guess.
  8. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    It wasn't fully seated. It doesn't align with the other pulleys and was eating belts.
  9. ColinGreene
    438
    293
    Orange county Ca
    Then get a press tool and drive it all the way on? Usually a bolt with some greased washers is plenty enough to drive it on.
  10. GeorgeCo
    Oct 29, 2009
    253
    38
    Motorer
    Mt. Airy, MD
    FYI: This tool works to remove it, but you have to use the longer bolt/greased washer method to reinstall. Wilmar W89711 Harmonic Balancer Puller
    Sells under many different brand names, but if you just search by the part number you'll find it at your favorite tool source.
