Pulley Puller?
Discussion in 'Mid-Ohio Motoring' started by cooperjet, Feb 14, 2013.
  1. cooperjet
    cooperjet Well-Known Member
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    Thinking about tackling the supercharger pulley myself before MOTD and wondering if anyone around here has a puller I could borrow/rent/buy. :fingerscrossed:
    I don't have one. Call Aaron he may have one to loan out if you buy your pulley kit from him.
  3. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    Planning on ordering from him. Hoping for something local before I go that route.
  4. JMC40
    JMC40 Well-Known Member
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Chris I would be willing to split the cost with you for a puller if no one has one to borrow. I am also in need of the belt tensioner tool if any one has one of those to borrow.
  5. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    That might be the best option. I thought your R53 had a pulley done already.
  6. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    Oh, and Nathan has offered up the use of his tensioner tool previously.
  7. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    It does but I think I am going to be replacing the supercharger...
  8. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    Gotcha. Guess I will add a puller when I place my order then. Do you have a time frame for getting this done?
  9. CHKMINI
    Chris, let me check to see if whoever borrowed my puller returned it. If so, I'll bring it to breakfast on Saturday.
  10. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    Thanks Mark. I won't be able to make it to breakfast but I can figure something out if you find it.
    Donut puller :donut1:
  12. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Mark I will grab it from you, if you have it as I will be needing one in the next week or so.
    Have you determined your SC is FUBAR Jason?
  14. cooperjet
    Sep 4, 2009
    1,057
    197
    Pensacola, FL
    That sounds like a good plan Jason. Let me know when you are doing the swap. Maybe we can do them both at the same time.
  15. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    No, but I found a good deal on a low mileage one on the "Site that shall not be named..." :D
    So I figure while I have the front of the MINI off I will go ahead and replace it, for piece of mind. If I find the original is okay, then I will probably just replace the oil. Then I can either sell the other one or just keep it on the parts shelf for when I do need it. All I know is I have two boxes O'stuff that will be getting replaced...
  16. JMC40
    Sep 1, 2010
    1,745
    368
    O...H...!!
    Will do, I am probably going to start tearing into it next weekend.
  17. Crashton
    Wrenchin.... Wrenchin.... Wrenchin.... :arf:
