1st Gen R53 Cooper S Pulling to the left during acceleration
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by matchframe, Oct 24, 2016.
  1. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Video Tech for Boeing at NASA Houston
    Dickinson, Texas
    My son's '06 R53 with six speed has an interesting issue, He was home for the weekend and he said that when he accelerates there is a pull to the left. I took it out for a drive and it does pull hard to the left during acceleration but goes perfectly straight all other times. It handles and steers well too. A few months ago, I replaced the drive shaft on the drivers side, could it be possible that the clip that holds the shaft in the transmission may not be holding? Could that shaft be pushing outward during acceleration? That is the only thing I can think it might be.
    Thanks for any advice and opinion.
  2. DneprDave
    It sounds like regular old torque steer.
    Are you sure it didn't do it before?
  3. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    It pulls really hard to the left. Yesterday I was on an entrance ramp to a freeway here in Houston which curves to the right, when I accelerated it pulled to the left, I thought I was going into the barrier.... it pulls that hard even under slight acceleration. You can see the steering wheel turn to the left as well.
  4. rusty.daily
    rusty.daily New Member
    Aug 8, 2015
    9
    I've seen a couple where the trans mount nut has backed off a few turns, that has caused some pulling issues
  5. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Thanks, I will look into that.
    Look at the lower control arm bushing while you are at it. They are usually toast by 50K or so.
  7. MCS02
    And replace them with powerflex bushings
  8. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Could a worn bushing cause the pull during acceleration?
    Yes it is one of the things that can. With the worn out bushings it will let the arm move back & forth. When mine were worn out I didn't really notice a hard pull. Once they were replaced with Powerflex bushings I could feel a real difference. It is worth checking those bushings while looking for your problem.
  10. Dave.0
    I would have the alignment checked first. Your son may have hit a very bad pothole or curd and jacked up the alignment. :rolleyes:
    Also failed OEM Lower Control Arm Bushings will absolutely cause this issue also.
  11. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    The alignment is what I first thought of but it goes perfectly straight when not accelerating. It corners well and tight. when I let off the gas and let the steering wheel go it goes perfectly straight. When I press the gas the steering wheel goes about 30 degrees counter clockwise, or to the left.
  12. cct1
    Nothing you can do about it, it was previously owned by Bernie Sanders.
  13. MCS02
    Kick the front of the front tires, if they move back any at all you need lower control arm bushings.
    Or you can jack it up and see or they move back and forth, if so its time for some Powerflex bushings.
  14. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    #14 BlwnAway, Oct 25, 2016
    :lol:, I think someone would have noticed that.....
    There would have been cheese all over....
  15. cristo
    cristo Well-Known Member
    Jan 4, 2015
    5,712
    924
    physician
    York, Pa
    Another vote for failed lousy oem control arm bushings,
    but also give a good look at ball joints and tie rod ends
    just for completeness.
  16. matchframe
    matchframe Member
    Aug 3, 2009
    67
    15
    Dickinson, Texas
    Update: I found what was causing the problem, on the driver's side, the inner ball joint (I guess that is what it is called) where it bolts to the sub-frame, the two bolts were loose. I pulled the bolts to look for any damage and they looked good. I coated the threads with lock-tite and torqued them back in. The Mini drives good and straight.
    The reason it took me this long to find the issue, is this Mini belongs to my son who is a student at Baylor. He was home last week and that gave me the opportunity to take care of this.
  17. 00Mini
    Nice find !!
