Suspension Brakes 1st Gen Question about Lowering
Discussion in 'Tuning and Performance' started by minimaniac, Jan 29, 2014.
  1. minimaniac
    minimaniac New Member
    Jan 29, 2014
    I got a 2006 mini , I look for coilover kit, what is the best between v-maxx and fk street-line, I want to be low but keep little bit of comfort...its a street use only
    and I look for rear adjustable control arms and adjustable camber plates, what I need if I want to be very low and adjust the camber to fit my 16x9 wheels.. thanks!
    sorry for my bad english, im a francophone ahah
  3. minimaniac
    Jan 29, 2014
    Thanks, bit I look for a kit under 1500$ ...
  4. Dave.0
    Well then I would not buy any and just save up because cheap coil over kits don't last and I would hate to see you flush $1,500 down the drain.
    Just being honest. :Thumbsup:
  5. Apex
    Apex New Member
    Jan 19, 2014
    96
    NJ
    If you really want coil overs, do what Dave suggested and save up for a quality set. In the mean time, you can always keep an eye out for a used set to pop up.
  6. minime331
    minime331 New Member
    Jan 27, 2012
    145
    30
    washington dc metro area
    I've got a set of Megan ' s and can't complain about them they do need fine tuning but so do all Co
  7. MCS02
    If its just for the street or a occasional AutoX or track day. maybe just some springs and good struts would be a better choice.
    I have Eibach Pro-Kit Spring Set and Koni Sport Strut - 3 way adjustable. I've been very pleased with them. The springs lowered the Mini 1.2in.
  8. minimaniac
    Jan 29, 2014
    Thanks for answers.. and does I need adjustable control arm or something to be able to adjust the camber?
  9. MCS02
    I do not have them although I do plan on one day getting them. If you do what I did I don't think it's a must but it would be better to have them.
  10. Dave.0
    If you go low you will need adjustable rear lower control arms and front adjustable camber plates.
    It would also not hurt to get (4) adjustable end links to get the anti sway bars back in the correct location and take out any preload when you lower your car.
    After all this is done and you set the ride height to a level you like THEN get a full 4 wheel alignment.
    You could skip all of the above if you don't mind burning up tires and replacing them very often. :rolleyes5::lol:
  11. MCS02
    Yea Dave is correct. I have plenty of camber. I also know the tire man very well. :rolleyes:
