1st Gen R53 Cooper S Question concerning underdrive pulleys
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by oldvet53, Feb 5, 2013.
  1. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    I'm getting ready to do a 15% WMW Supercharger underdrive pulley and a PRW Fluid Crankshaft Damper Pulley that I also got from WMW and did some checking and it is a 8.7% underdrive pulley. My question is what should I expect from this combanation, will there be low output charging problems with the alternator being underdriven at slow speeds like around town?:confused5:
    No experience, but yes the alternator is going to spin slower. Your supercharger is going to spin faster. You got a 15% pulley to be safe over a 17%. Now you are going to be somewhere near the same as the 78%.
    If it was Me I'd call Way & have him swap you a stock sized PWR damper for the undersized one. You have plenty of time to make the exchange before your pulley install.
  3. ScottinBend
    ^+1
    Get the proper sized crank puley.
  4. jiminni
    jiminni Well-Known Member
    262
    Ca.
    8.7% underdrive crank pulley? You sure about that? Never heard of such a thing. Most people use 2% OVERDRIVE crank pulleys :Thumbsup:
  5. Dave.0
    I would only run the stock size.
  6. jiminni
    262
    Ca.
  7. jiminni
    262
    Ca.
    And why is that?
    For me it would be turning the supercharger too fast. I went with a 15% pulley, because I intended to use my MINI on the track occasionally. From what I had read it was recommended to go with a 15% for that use. The 17% was said to be fine for street use, but not so fine on the track.
    If I remember correctly the OP said in another post that he wanted a 15%, because it was safe. His MINI is high mileage so I agree with his thoughts.
    Going with an under-drive crank pulley will turn the Supercharger faster than just the 15% with a stock sized crank pulley would.
  9. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    I talked to Way and he confirmed that the Crank Damper pulley was the stock size, I had looked on the PRW site and it said it was a underdrive pulley. Thus the confusion so I'm good. I should have just talked to Way first.
    I understand the confusion since both are listed. Good to know Way sent you the one you wanted. :Thumbsup:
  11. BlwnAway
    BlwnAway Well-Known Member
    Nov 24, 2011
    474
    290
    Glad it got sorted, I couldn't see a reason for it either, wonder if it was designed for a different veh. & just happens to fit our engines so they cross advertise it that way.
    Under Size Crank Pulley = Slower Accessories
    Under Size Accessories Pulley = Faster Accessories
  12. Kavs
    Kavs New Member
    Nov 22, 2011
    13
    If you tell me diameter of crank pulley I can suggest to you exact pulley size which will match to your mods and wishes. A big range of pulleys is from -11 up to -20%.
