Suspension Brakes 1st Gen Quick question Brake fluid
Discussion in 'Tuning and Performance' started by MCS02, Apr 29, 2016.
  1. MCS02
    I'm too lazy to look it up and I am on the road so I can't get to my Bentley manual.
    How much brake fluid do I need to flush the break/clutch system?
  2. Minidave
    4,591
    1 pint will usually do it, buy a quart and you'll have extra left over in case you need it.
  3. MCS02
    Thanks Dave!
  4. Rawhyde
    Rawhyde Active Member
    Apr 7, 2012
    311
    233
    Facilities Engineer
    Mountains of NW Georgia
    If you have any left over, throw it away. Brake fluid is extremely hygroscopic. (It absorbs moisture from the air.) When it absorbs moisture, its boiling point is substantially decreased and its vapor pressure is increased. Water contaminated brake fluid is what causes a spongy and mushy feeling brake pedal.
    You're not saving any money by keeping containers of brake fluid around your shop once the seal is broken.
  5. BlimeyCabrio
    Some fluids are more sensitive to this than others. FWIW, I've used Super Blue / Type 200 for almost 10 years in the Mini, have never thrown away a partially used container, have frequently bled using a container that was opened (and re-sealed) months earlier, and have never had a problem, including running very aggressive mountain weekends on track pads, and track days. I'm not saying it's not a problem for some people... but it's never been a problem for me.
    The only time I've ever had a spongy pedal, was with some air in the ABS system.
  6. MCS02
    #6 MCS02, May 1, 2016
    I ordered ATE 706202 Original TYP 200 I guess its not blue anymore. I have had the wilwood fluid has been in my car for 2 years.
    Paul did you mean, "The only time I've ever had a spongy pedal, was when I was in the air with my ABS" ?:biggrin5:
  7. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    same here with reusing opened container fluid. There's only so much moisture that can be absorbed from a half liter of air. I don't leave it sitting in the pressure bleeder, as that is open to the atmosphere when not in use.
    If I have leftovers, I usually run those leftovers through the system first, to pre-flush reservoir and lines, then switch to content of a fresh can of ATE 200.
