1st Gen R50 Cooper R50 Closing in on 50,000 miles
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by M1N1, Apr 19, 2014.
  1. M1N1
    M1N1 Well-Known Member
    Jan 5, 2014
    726
    329
    Tool and Die Maker
    NW Ohio
    #1 M1N1, Apr 19, 2014
    R50 Closing in on 50,000 miles. What to look for?
    My '06 R50 is getting close to having 50, 000 miles on the clock. What do I need to look for as it hit's that mileage?
    I have already decided on Powerflex control arm bushings to replace the OEM rubber:Thumbsup:
  2. N2MINI
    N2MINI MINI of the Month
    Dec 4, 2009
    3,349
    575
    Sign Maker
    Could be any number of things or nothing. Depends on how anal you are about maintance and if you have the money to spend to replace stuff just because. Few things to check are, belt, motor mount, all bushings to name a few. Guessing you have already done brakes and battery. If not somehow that will be soon.
  3. ZippyNH
    Inspection 2 is normally done at around 60,000.....
    With so much age and so few miles....hopefully it was done long ago....
    My suggestion....
    Do an inspection2 with a fluid change for the cooling system and brakes if the last change is unknown....that will literally cover everything, since inspection2 is so complete.
  4. Way Motor Works
    Way Motor Works New Member
    206
    MINI Tuner
    Atlanta
    Do the Inspection 2 service. And based on age of the car I would also do the plugs and plug wires if they are the originals.
  5. iovecables
    iovecables Member
    May 25, 2014
    72
    City Transit Operator
    Ottawa, Ontario, Canada
    Why bother if the originals are in good shape?
    If the plugs or wires go bad they will take out the coil pack along with it. Plugs & wires are cheap insurance the way I see it. No need for fancy plugs, wires or an aftermarket coil, oem ones will work fine.
    Since you have a CVT I'd have the fluid changes as a preventative measure.
  7. Different Computers
    Different Computers New Member
    Apr 7, 2014
    171
    68
    Mac Guy
    Troy, VA
    How does an 8 year old car have such low mileage?
    Of course, I ask that when I was just as astonished that Black Top only had 91K miles on it when I bought it. That's under 10K miles a year!
    Seems that many MINIs live their lives as a third fair weather car. Sure keeps the miles off them. My is my daily driver & gets loads of use. Although the mile accumulation is slowing down since I've retired.
