This is a one off custom exhaust system fitment to an 2002 R53 MCS I designed this up and ran it for about a week on my MINI about 5 years ago? It has been stored since collecting only dust. The sound this system makes is very similar to the one depicted in the provided youtube video only louder and more aggresive. That said it is not for someone wanting an un noticeable sounding MINI. The mounting brackets in the center are for the oem mount and the end pipe will fit easily with only slight modification. The front flange will fit an OBX w/o CAT. If you have stock or other hedder configuration cutting the flange off and attaching the appropriate flange is an easy mod at any exhaust/muffler shop. Because of the length it is not a shippable item and must be picked up. I am asking $300 which is extremely reasonable for what you get. Video available from YouTube - Broadcast Yourself. [ame=http://www.youtube.com/watch?v=XBluGVplct4&feature=player_embedded]YouTube - IMG 0997[/ame]
If you want this part then contact the seller directly. There are to many issues with the way this was done to leave it open.
