Engine Drivetrain 1st Gen Cooper S R53 intake on a R50?
Discussion in 'Tuning and Performance' started by RallyMini370, Jun 3, 2015.
  1. RallyMini370
    Seeing as I can use any parts from Mini can a S intake be modified to use the R50 throttle body without the super charger? would there be an advantage?
    [ame=http://www.ebay.com/itm/03-BMW-Mini-Cooper-S-INTAKE-MANIFOLD-OEM-1-6L-1161-1524-533-03-/301643727744?hash=item463b5e0380&vxp=mtr]03 BMW Mini Cooper s Intake Manifold 1 6L 1161 1524 533 03 | eBay[/ame]
  2. Eric@Helix
    Eric@Helix New Member
    1,257
    Shepherd
    Philadelphia
    It certainly wouldn't be a direct bolt-on, but where there's a will, there's a way...
  3. MCS02
    If you can use any part from Mini how about the Supercharger? They will never notice.:D
  4. RallyMini370
    I think the 10:5:1 CR will notice! lol
  5. TheModFather
    You can, and Jan actually has the part you would need to adapt the throttle body to bolt onto the intake manifold with his upcoming turbo kits... Tuning would be required though, its a pretty big change from the stock Justa plastic manifold configuration. ;)
  6. RallyMini370
    I'm pretty sure the boys in the machine shop can knock up an adapter but if tuning is required then that could be an issue.
