1st Gen R53 Cooper S R53 JCW upgrade on the cheap
Discussion in '1st Generation: 2002–06 R50, R53 & 2004–08 R52' started by AliceCooper, Feb 10, 2013.
  1. AliceCooper
    AliceCooper Club Coordinator
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    There is a set of front R56 calipers up in the market place on the sewing site for cheap, if you have a R53 and have been desiring a upgrade go get em!! they will bolt on to your R53 just need rotors and R56 brake lines.
  2. jiminni
    jiminni Well-Known Member
    262
    Ca.
    Wonder if it's much of an upgrade? One of my last mods a will be a BBK as soon as I need new brakes. Wilwoods number one on my list, how would the stock R56 compare to them? Anyone know?
  3. AliceCooper
    Mar 13, 2010
    643
    123
    CT Technologist
    South Florida
    The R56 calipers are essentially what was the R53 JCW upgrade, you would have to only upgrade to the R56 rotors and lines. For the R53 I would say its a nice upgrade and definately as I stated in the title.
  4. Dave.0
    It is a very nice upgrade over the R53 brakes.
    Every R53 needs R56 brakes just like every r56 needs the sound of a Supercharger.
  5. BlimeyCabrio
    Very nice upgrade.
    With the right pads, this is a better setup than a BBK for 99.78% of Miniacs.
    You actually need 1st gen JCW lines, NOT 2nd gen lines, to fit these on a 1st gen car. Or custom lines with the R53 car end and the second gen MCS caliper end (which is the same thing as 1st gen JCW lines). Plus appropriate rotors.
  6. ChrisMCS04
    ChrisMCS04 New Member
    May 12, 2009
    92
    14
    Could someone please tell me what tap size the caliper end of these lines are? I have a ss braided set on the r56 calipers now and am about to replace the calipers and rotors with a set of 4 piston outlaws and 1.25x11.75 rotors and would like to tap the calipers to fit these lines.
    Thanks.
  7. oldvet53
    oldvet53 New Member
    Oct 21, 2012
    277
    79
    Disabled/Retired
    N.E. Arkansas
    I'm going for a upgrade that WMW has that still fit's inside the stock 16" wheels and stainless braided Brake lines. I see a lot of folks going to the larger wheels but I have found a very light set of 16"x7" Konig's and plan on staying with the 16" size as you can find light wheels and as you go up in size the wheels get heavier and the sidewalls of the tires get smaller so that they will end up riding like the Run flats that I will be replacing as soon as the are gone with a better dedicated Summer tire and use the stock Daytona 5 spokes with a all season in winter.
