MINI R53 New owner
Discussion in 'Starting Line - New Member Introductions' started by guitos, May 19, 2019.
  1. guitos
    guitos New Member
    May 19, 2019
    12
    Can someone help?
    I have a 2002 R53 cooper S and today we let me down.
    I turn the key, the engine rolls but no start. Any ideas?
    Thanks in advance.
    Hugo
  2. Sully
    Sully Administrator
    Jul 21, 2015
    Software
    30350
    You are probably going to get more questions at the start. I’m not a R53 expert, first thing i would do is Check for spark and fuel.
    I did a quick search and a few threads came up. May want to review some of them.
    https://www.motoringalliance.com/threadloom/search
  3. MCS02
    Welcome to MA!
    How many miles does it have? has it been modded or is it stock? Do you know the mainlanders history? Have you checked to see what codes are showing?
    See @Sully was correct, more questions.:D
    Let us know we will try our best to help
  4. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    Something common on BMWs is the fuel pump relay goes causing it to turn over but not start.
    Also see if you can hear the pump prime when you turn the key on (no crank)
    Sent from my iPhone using Tapatalk Pro
  5. guitos
    guitos New Member
    May 19, 2019
    12
    Hello,
    Thank you very much for your feedback.
    The car have at the moment 160.000 miles on. Its all stock. The previous owner had the car since new and always serviced it on BMW garage.
    I already change the spark plugs but still no start. I dont have the error code reader. I really need to take in to a garage to see what is wrong. Thanks anyway.
  6. wmwny
    4,040
    2,242
    Auto Zone [as well as other auto parts stores] has code readers and they can help you find the codes errors...for free. This should save you a trip to a garage until you better know the problem.
    Good luck, and welcome to M/A!
  7. MCS02
    If you can pull a plug and spin it over and see if your getting spark if you are then it must be a fuel problem. then check the relay like @o2sys said.
    It would be well worth buying at least a basic code reader, even better to buy one that reads BMW/MINI codes. It will pay for itself.
  8. Dave.0
    At 160 k I am going with OEM fuel pump finally died and I would replace that and the 160k old fuel filter at the same time.
    • Like Like x 1
    • Agree Agree x 1
  9. guitos
    guitos New Member
    May 19, 2019
    12
    Hi.
    Already buy a code reader. Just waiting to arrive then i will post the error codes that appear to see if there's any light on that. :)
    Thanks for your message.
    Regards
  10. guitos
    guitos New Member
    May 19, 2019
    12
    Hi,
    Already check and no spark on the plugs.
  11. MCS02
    Ok, then check the connections on your coil pack make sure they are clean. If you replace the coil pack stick with OEM, they are good for something like 300hp. Those pretty red ones cause problems. Also check all your fuses.
  12. Dave.0
    The R53 OEM coils are good to over 550 + WHP. Fixed the for you Lee.....:D
  13. guitos
    guitos New Member
    May 19, 2019
    12
    Hi.
    All the fuses are good.
    Maybe its the coil pack that went dead? Its normal to happen? Also can have something to do with the imobilizer?
    Thanks in advace for your help.
  14. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    Immobilizer cuts off fuel so it should crank but not start if it's the immobilizer.
  15. MCS02
    Thanks, as I typed that I know I was more than likely WRONG!!:D
  16. guitos
    guitos New Member
    May 19, 2019
    12
    Hi all,
    Today the reader have arrived and already done the scan.
    Present 2 errors
    P0336 - Crankshaft sensor: interference on crankshaft signal
    P1617 - Unknown error code ????
    If any one can help i will appreciate.
    Regards
  17. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    A faulty crank position sensor will not start the car. Car needs timing reference and with out it, it won't start. It's magnetically read.
    Check if it's connected probably, any wire damage and if it's leaking oil from the o-ring seal.
    Then replace if needed.
    • Like Like x 2
    • Agree Agree x 1
  18. MCS02
  19. guitos
    guitos New Member
    May 19, 2019
    12
    Hello.
    Already replace crank position sensor but the car is still not starting.
    The code P0336 already clear but no start.
    Can someone help?
    Thanks
  20. o2sys
    o2sys Active Member
    May 20, 2019
    101
    161
    Have you checked all the ground wire/straps in the engine bay? Especially the one on the passenger side engine mount?
    Check if it's tight. When I did my belt I forgot about the ground wire and would crank but not start.
