Exterior 1st Gen R53 Noisy sun roof.
Discussion in 'Tuning and Performance' started by TaylorP, May 10, 2014.
  1. TaylorP
    TaylorP New Member
    Nov 23, 2013
    17
    My power Sun roof has started to make a grinding noise when closing. Almost slows to a stop. Help!
  2. wmwny
    4,048
    2,246
    white lithium grease spread copiously on both sides of the tracks solved my wife's R53 sunroof problem after the dealer claimed the tracks were worn out and that I'd have to get a new sunroof.
  3. ZippyNH
    I'd clean the old grease off with a rag and some wd-40....bet it has a few years with of dirt and grime....then re-grease it...bet a good syenthic waterproof grease would be fine...red or even blue grease....just a few dabs will be all bit needs!!
  4. beken
    beken Well-Known Member
    Jan 13, 2010
    1,405
    1,829
    Delta, BC
    Yes...you need to grease the rails from time to time.
    Also, when my car was about to go out of warranty (a few years back), the dealer drilled some holes somewhere to allow for better drainage of any water that might get trapped in there.
  5. Dave.0
    Welcome to M/A the FUN Mini site. :Thumbsup:
  6. TaylorP
    TaylorP New Member
    Nov 23, 2013
    17
    Thanks I bet these hints will be the cure. It gets better after a rain so I'm sure these will do the trick. Much thanks.
