R53 proactive parts replacement
Discussion in 'MINI' started by JackMac, Dec 18, 2017.
  1. JackMac
    JackMac Well-Known Member
    Jan 1, 2010
    399
    251
    PA
    #1 JackMac, Dec 18, 2017
    The head and supercharged will be upgraded on my 193k mile 2003 in a couple of weeks. Want to be opportunistic and proactively replace a few other things at the same time, as many parts need to be removed anyway as part of the process.
    Below is a short list. What else do you think should be replaced out of convenience?
    Belt
    Cam position sensor and gasket
    Intercooler boots
    Water pump and gasket
    Thermostat and gasket
    Upper and lower radiator hoses
    Fuel regulator line
    You are taking it to Helix right? You know the boys will look it over and let you know what needs replaced.
    Also add thermostat housing since they crack and cause a leak. :Thumbsup:
    Timing chain tensioner.
  3. JackMac
    Jan 1, 2010
    399
    251
    PA
    #3 JackMac, Dec 18, 2017
    Yeah I talked to Eric and his general advice was to wait until stuff breaks. I'm trying to avoid paying future labor charges by taking care of a few things in advance with this one.
    Good call on the chain tensioner. I also need a crank position sensor (gasket is leaking, like they all do).
    Decided to get stoopid and doing a bunch of stuff to this car, and want to be sure the basics are also taken care of.
  4. Canusrufis
    Canusrufis RMW Powered R53
    208
    103
    Winston Salem NC
  5. MCS02
    I second the oil filter housing gasket. I replaced the on on my 02 this last summer. I also replaced the water hoses going to it they had started to swell because oil had gotten on them.
  6. fishmonger
    fishmonger Well-Known Member
    May 13, 2015
    984
    769
    Madison, WI
    stuff that goes out around the motor not listed so far:
    add new chain guides to the tensioner
    Engine harmonic balancer if still OEM
    belt tensioner
    idler pulley
    AC clutch
    fuel filter
    fuel pump
    clean the inside of the intercooler and pretty much the entire intake path, especially throttle body butterfly and the bypass valve mechanism
    engine mounts - I'd go 30k miles tops for the upper, while the lower and gearbox mounts can go much further
  7. MCS02
    Lets just make this easy for you. RMW stroker motor and aquamist system. just add some new hoses and fuel filter for good measure.
    There done. :D
  8. Dave.0
    #8 Dave.0, Dec 18, 2017
    John (Jackmack) knows what he is doing and this is not his first MINI. Heck it may be his 5th MINI as I have lost count. He has had 3 R53’s both GP’ss and an WC 50 or whatever it was called. I am just glad he always comes back to the R53 first gens. He knows how to take care of a car and I would buy any car he offers up for sale.
    John, yeah I know how Eric is but I am with you, fix it before it breaks. I wish you would have kept the blue R53 “Bad Dog” as that was a very cool car.
    Let me know if you want to chat. Just shoot me a PM and I will send you my number.
  9. JackMac
    Jan 1, 2010
    399
    251
    PA
    #9 JackMac, Dec 18, 2017
    Dave, thanks I’ll take you up on that. I’ve been in contact with the current owner of Bad Dog. Almost bought it back last year, but they backed out. So I bought this 2003 as an extra car and to teach my son how to drive stick.
    One thing lead to another, now I’m going in deep with mods and fixes. Not as far as some people, but got my hands on a few things and will make it nice.
    7 MINIs so far, including 4 R53s. Yeah, keep coming back to them. It’s where the fun is.
    @fishmonger - Already did the bypass valve and belt tensioner (both had failed). Also replaced the fuel pump and fuel filter. And far more than I care to admit right now!
    Stacks of parts currently in the garage for winter projects waiting to be installed, including R56 front brakes, SS brake lines, aero bumper, grills, and side skirts, M7 strut brace, new JCW suspension, new GP rear bumper trim, new JCW steering wheel, airbag, and MFSW conversion, Milltek header, etc, in addition to the stuff at the top of this post.
    It’s “go†time. Probably do a build thread in the Spring with photos and details.
  10. Dave.0
    John do you still own the MINI catalog / car show JCW car? That is a damn nice car . :Thumbsup:
  11. JackMac
    Jan 1, 2010
    399
    251
    PA
    Oh yeah, that’s a keeper. 26K miles.
  12. MCS02
    Is that the 2006 JCW?
  13. JackMac
    Jan 1, 2010
    399
    251
    PA
    Yes, that’s the one.
  14. MCS02
    That is a great car!
  15. JackMac
    Jan 1, 2010
    399
    251
    PA
    Thanks all for the feedback. Here is where I ended up including:
    Crank position sensor and gasket
    New Intercooler and boots (current intercooler has a broken bracket)
    Thermostat, housing, and gasket
    Fuel regulator line
    Oil filter housing gasket
    Timing chain, tensioner, and guide rails
    Oil change/filter
    That's it for now, plus of course the other major work that was being planned which started all of these extras!
    If you haven't done so already you may want to add an ATI damper to your list.
  17. JackMac
    Jan 1, 2010
    399
    251
    PA
    Was going to do that until seeing the price tag.
  18. MCS02
    Its just money
    At the mileage your MINI has it may be money well spent.
  20. JackMac
    Jan 1, 2010
    399
    251
    PA
    #20 JackMac, Dec 19, 2017
    Ok, I’ll bite. What are the risks/benefits of replacing the crank pulley with the ATI damper now? If the crank bearings are worn, isn’t it too late?
    Open to opinions on this.
